Piston ring order
Piston ring order
Engine: 3.0, V6
Do you count the piston rings from the top (ring 1, ring 2, oil ring), or from the bottom (oil ring, ring 1, ring 2).
Thanks
Thanks
I think it's from the top. Never had any reason to number them.
But I'm guessing you're trying to install a new set of rings, maybe? In that case, the silver ring goes on top, printed side up (if there is any printing).
top down
#1 comp. ring
#2 comp. ring
#3 oil rings/expander
dots or other markings go up toward the top of the piston, dont forget to measure the end gap and stagger them too, good luck
#1 comp. ring
#2 comp. ring
choppe777
05-16-2016 08:00 AM
