Piston Ring End Gap 22re
Old 04-25-2015, 06:15 AM
shopman809's Avatar
Hi All,
Rebuilding my 22re for my 89 4x4 pickup. I got some new piston rings from Sealed Power. While checking the ring fitment in my cylinders prior to installing them on my pistons, it seems like my No. 2 ring is consistently too tight per the Toyota FSM specs. All four cylinders are gapping at 0.015 - 0.016 thousands. FSM says minimum for No. 2 is 0.023 thousands. No. 1 ring and the Oil groove rings check out fine per the FSM.
My question: Can this rebuild work with the No. 2 rings at 0.015 gap or should I file the rings to open the gap to 0.023 thousands?? Advice would be much appreciated! Also, this is a regular overhaul not racing, etc.
Thanks,
bigjstang
08-25-2021 12:41 AM
young buck
18
08-27-2018 02:40 PM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Piston Ring End Gap 22re
