pinch weld, sawzall or BFH??
Old 08-22-2007, 08:39 AM
TC4RNR's Avatar
that's for the front wheel well. anybody can link a write-up for me?
thanks.
Old 08-22-2007, 09:24 AM
chimmike's Avatar
what?
Old 08-22-2007, 09:31 AM
04 Rocko Taco's Avatar
cut it, grind it, beat it, wheel it.
There now I have given as much, if not more, info answering your question as you did asking it.
Old 08-22-2007, 09:58 AM
TC4RNR's Avatar
Originally Posted by chimmike
what?
here you go,
with bigger tires and wheel spacers now, i ran into this rubbing problem.
first picture, driver side, while steering wheel turned to left
second picture, passenger side, steering wheel turned to right.
close-up
i have red about trim down the pinch weld but never learned how and how much. need someone to school me on this.
thanks.
Old 08-22-2007, 10:23 AM
tc
tc's Avatar
It's really not that complicated ... just do what you got to do to clear the tire!
How? remove the plastic liner, you will see the pinchweld behind it. Beat the crap out of it.
How much? Until it's flat or the tire clears. Careful on the passenger side because the ECU is right there.
Note: for best effect, you may need to trim the lower outside corner of the plastic liner off.
Old 08-22-2007, 10:35 AM
ewong's Avatar
BFH if you are NOT tubbing" it.
Sawzall of the pinch weld ONLY if you never see water.
Otherwise rust city and wet floor boards.
If you were tubbing it you woudl already know what to do...
Pull the inner liner
take a look at the seam that stick out.
Hammer flat
There are NUMBEROUS writeout out there - see 4x4wire or pirate4x4
Old 08-23-2007, 08:45 AM
TC4RNR's Avatar
well, BFH prevailed again! i did woke up few neighbors a little bit earlier then they wanted to, but i sure did have fun. a BFH got the pinch weld done and box cutter took care of the trimming of the plastic liner.
thanks guys.
Old 08-23-2007, 08:52 AM
RunnerUp's Avatar
BFH's fix much more than pinch welds....
Old 08-23-2007, 09:40 AM
tacoma728's Avatar
The tires will take care of it over time.
Old 08-23-2007, 11:01 AM
olharleyman's Avatar
here you go,
close-up
thanks.
I uesd a whiz wheel to do mine for my 35's and trimmed down the area from the bottom to about half way up the front and have zero problems now.
Its very easy and only took about 5 mins to do both sides , take the whiz wheel about 1/4 inch from the rear side of the tire of towards the door and cut the pinch weld at a angle and just continue forward around the bottom and up the fender well about 1-1 1/2" up and angle it to look good then move on to the other side and thats it.
Also almost forgot to say pull your plastic fender saver things out of the way and when your done they will fit just like new again.
Old 08-23-2007, 02:16 PM
waskillywabbit's Avatar
ladybugRC
458
08-21-2020 10:41 AM
tazman1972
11
09-28-2015 10:32 PM
runnermedic
13
09-21-2015 05:20 PM
themightykhoner
09-18-2015 02:28 AM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: pinch weld, sawzall or BFH??
