Pics of throttle cable bracket and more
Old 08-20-2009, 12:14 PM
Ironmike4x4's Avatar
I've searched for just 22r pictures which some dont show clearly enough to see, but I'm in the process of getting my engine back together. Its been over a year since I had the motor out and now have forgotten where the throttle cable bracket went. If anyone would volunteer to take pics of theirs on the 22r I'd greatly appreciate it. I also need pics of the vacuum hoses from the distributor to where it goes and the little cable that runs above the throttle cable (I'm assuming a heater switch valve). Thanks in advanced.
Old 08-20-2009, 05:05 PM
yoterr's Avatar
well the throttle cable bracket should go on the back side of the valve cover...
Old 08-20-2009, 05:07 PM
yoterr's Avatar
heres some pics of what i got, is a mess and pretty dirty lmao
Old 08-20-2009, 06:02 PM
Thank you so much yoterr. The engine I bought was from a guy that eliminated a bunch of his smog equipment so I'm kind of back tracking to find out what is necessary for it to run and what is fine to leave off. I'm guessing the vacuum lines are also uneeded for the smog elimination? It looks like it goes to the "rows" of hard lines. Also if anyone else doesn't mind I need a picture of the valve or whatever it is to the heater hoses? When pulling the motor it got hung and rearranged it a bit.
Old 08-21-2009, 04:44 PM
yoterr's Avatar
yeah most of the hard lines are for smog, i think the only things you need are the vac advance lines and the AAP(Auxilary Accelerator Pump) line attached to the vsv on the intake manifold.....annnnnndddddd i think theres one that goes the the charcoal canister you need too, and of course the break booster and i think i know what ur talking about on the heater houses, ill go take a pic real quick
Old 08-21-2009, 04:58 PM
yoterr's Avatar
is this what ur talkin about??
Old 08-21-2009, 10:47 PM
yep that's it, the cable is out and not sure where to put it back. Is it really important? I'm thinking its some sort of valve for the heater?
Old 08-22-2009, 09:17 AM
yoterr's Avatar
thats my guess, but it doesent move with any of the ac/heat controls? if it wasent rainin ide track her down and see what it does, im kinda curious..
kazuya2416
04-05-2024 02:17 AM
okamikai
04-30-2018 10:19 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
rbh261
07-13-2015 12:04 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Pics of throttle cable bracket and more
