Pics of Downey IFS Front Truss anyone?
Ordered the IFS Truss and got around to trying to bolt the thing up today, the Downey install instructions suck balls as always, so holding it up I just can't see where the sucker goes. Where I thought it went is about 1/2" too narrow to fit it up there. They sent me the 17" for a 86-88, maybe my front end was swapped for a newer year by a previous owner and I actually need the 16 3/4" one.
Anyway, if someone has a pic of theirs mounted - it would be much appreciated. So I can see how it mounts.
I don't have a pic, nor Downey anything, but according to them, the truss mounts between the lower pivot points of the lower a-arms.
the best I can figure is that it would go where the truss that came with my kit is.
Do the instructions mention drilling holes?
Do you have a pic of the truss?
*edit- wow, I just realized that my front end is sagging...
I have a Sonoran Steel Front Truss but they do the same thing so I'd assume they install similarly:
Before:
During:
After:
There are some instructions for the Sonoran Steel Truss:
http://sonoransteel.com/Early_IFS_Brace.html
Where abouts in Mesa do you live? I could give you a hand if you need. I'm in Chandler near Dobson and Warner.
Before:
During:
After:
Yeaa - I stumbled on the Sonoran Steel one and figured that's where the Downey fit. But it's way to long to fit up there, plus I don't think it's gonna fit with my Diff Drop. I may just pull the Diff drop and order the same one from Steve.
just use grade 8 hardware....
and i always wanted that soroan one but you gotta catch him on an order but he really makes nice stuff..just wish more for the older trucks but thats neither hear nor there lol
Because I am FLAT broke right now. I though about welding it up myself if I can find the materials. Let's see some more pictures.
Thats all I have of mine - you can always see more at Sonoran Steel's site:
What about Total Chaos's? It is made to weld on and be able to remove the diff.
When I ordered mine through trdparts4u, it wasn't made by Sonoran Steel, but instead by RockTech(?). I think it was only $80 or so. Looks identical to the Sonoran except it has a smooth bottom and doesn't have those welds protruding like those in the pics. I installed mine with grade 8 bolts instead of welding it. Took some finagling and a little bit of grinding to get it on since the Toyota welds were too thick to slip the brace on easily. Hardest part of installation was drilling the holes.
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
