Pic request of underwood fuse panel
Edit....yes underhood fuse panel, or whatever the technical term is. Stupid ipad correct.
If someone can post pics of their fuse panel cover that still has the sticker on it, I would appreciate it very much.
I have two here and both are just black with no info as to what it what. Doing some wiring reconfiguration and would rather not guess which fuse is for what circuit.
Working on both 22re and 3.0 86-88 runners. It's the small, L shaped panels. If you can post yours, please include the year and motor yours has.
The "Underwood" fuse panel is for the built-in typewriter. I think it was only an option in '88.
Relay Block 2 http://personal.utulsa.edu/~nathan-b.../2powersou.pdf contains fuses and is under the hood. Presumably, the configuration is different for dntsdad than that shown in the '93 manual.
I am wanting to just write functions out with a silver sharpie. This is ny nephews truck and was just trying to simplify things.
Looks like this.
Looks like this.
Fuse labels on mine...
1987 standard cab 4x4 with the 22rte/5 speed. I've seen the same label on 22re's at the junkyards. Can't speak for the 3.0 though.
I also have the 1987 FSM and Electrical Wiring Diagrams. One of these days I'll get around to scanning and making a .pdf out of them...
Underhood fuse panel cover:
Driver's kick panel fuse cover:
Diagnostic box label (inside the cap):
theking11863
03-19-2016 09:36 PM
rushw
07-18-2015 01:46 PM
