Persistent valve noise 22RE - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-03-2008, 06:15 PM   #1 (permalink)
Matt16's Avatar
I've already adjusted the valves and rechecked twice. Its only audible about 2500 rpm or higher, Is there anything else in the engine which can make the same noise? I can;t think what the problem might be.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 05-03-2008, 06:34 PM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Timing chain slap, noisy injectors, exhaust leak. That's all I can come up with.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 05-03-2008, 06:45 PM   #3 (permalink)
mudtoy1986's Avatar
what oil filter do you use
if its not a toyota oil filter u will have probs
there is a check valve in the factory filters that keep the tentioner tight
i found out the hard way 2 years ago also check the guides make shure they are still in good shape
also check your timing cover whaen the guides get worn to bad and the chain gets slack the chain will eat away the timming cover and cause it to expose the water jackets making you to think you have a blown head gasket
mudtoy1986 is offline
Old 05-03-2008, 07:28 PM   #4 (permalink)
I looked at a $3 Fram filter and a $11 Mobil-1 filter and didn't see an 'anti-drainback' valve. I saw a bypass valve that let oil around the filter if the filter was plugged, but no anti-drainback valve. The anti-drainback valve, it it is in the filter should block the center/input of the filter so oil didn't run back down the feed. Neither one had it.
I'm kind of guessing the mobil-1 didn't have it 'cause I poured about 1/4 pint of oil into the center of the filter and nothing came out when I turned it upside down... presumbably because the filter media had soaked up the oil and I could see the filter media looking up the center of the filter and down the 'output' ports as well.
__________________
Old 05-03-2008, 07:45 PM   #5 (permalink)
mudtoy1986's Avatar
well im not compleatly hure how the toyota filters are internaly difernet that aftermarket filters buy i do know that toyota filters should be used
they help prevent the timing chain slack and damage to the chain cover
Old 05-03-2008, 07:53 PM   #6 (permalink)
Matt16's Avatar
It doesn't sound like a timing chain to me but I'll take me stethoscope to it. I use a Wix oil filter. I'd be curious to see how an filter prevent timing chain noise. I'll replace the filter today. I replaced the timing chain three months ago.
Would injector noise change with throttle position, or rpm? That might be a possibility.
I don't think its an exhaust leak because its not dependent on load. I could be engine braking or flooring it at 2500 rpm and the noise is the same.
__________________
Toyota FAQ link
Matt16 is offline
Old 05-03-2008, 08:01 PM   #7 (permalink)
Considering the injectors fire all at the same time, on every revolution and stay open longer when the throttle opens...
It's probably an EGR passage / exhaust leak.
__________________
Old 05-04-2008, 01:40 AM   #8 (permalink)
Matt16's Avatar
I think its either valves or injectors. I just started it one day and it was there.
I'm certain its not an exhaust leak. I've had those before and the noise associated with a leak is present when the throttle is pressed down and silent when engine braking or coasting.
My understanding is that the EGR operated when the engine is hot. My noise is present the moment the engine is started
I listened with my stethoscope to the valves and none seem to be loud, though when I put the stethoscope on the nuts that secure the valve cover, some are louder than other nuts. The injectors sound loud when I put the stethoscope on them, but they all sounded roughly the same. Would injector noise come on this suddenly? What would cause this? How would I tell it was an injector?
__________________
Toyota FAQ link
Matt16 is offline
Old 05-04-2008, 02:03 AM   #9 (permalink)
Matt16's Avatar
How tight do you tighten your nuts? How much should the rubber grommets on the valve cover be compressed? I don't think I've over tightened them as I've done this many times, but who knows.
__________________
Toyota FAQ link
Matt16 is offline
Old 05-04-2008, 01:58 PM   #10 (permalink)
Matt16's Avatar
Anyone?
__________________
Toyota FAQ link
Matt16 is offline
Old 05-04-2008, 02:05 PM   #11 (permalink)
ovrrdrive's Avatar
Sure it isn't just pinging?
Btw, the nothing but toyota filters comment is complete bunk.
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 05-04-2008, 02:12 PM   #12 (permalink)
Matt16's Avatar
In the last little while, here what I've done.
  1. Set, reset and checked the valves, they're fine.
  2. Fixed the speedo (unrelated)
  3. Set the timing (maybe?)
It pings a bit, but always has. Set to 10* BTDC.
__________________
Toyota FAQ link
Matt16 is offline
Old 05-04-2008, 03:47 PM   #13 (permalink)
toyota_mdt_tech's Avatar
I bet you are over tightening your valve cover. If you do, it pulls up on the rocker assembly increasing valve clearances. Common mistake.
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Old 05-04-2008, 03:51 PM   #14 (permalink)
tortis's Avatar
i set my valves cold at 7-11. i use a 8-12 feeler gauge to check that they are not loose. if the 8-12 slide in they are loose. somebody on here a few months ago had a problem with an over tightened valve cover, but it made noise even at idle. when you replaced your t-chain did you replace the tensioner as well? does it run rough?
__________________
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
tortis is offline
Old 05-04-2008, 03:56 PM   #15 (permalink)
Valve cover bolts should be a little more than finger tight at 43-60 inch/lbs. I just did my valves and so far so good.
__________________
'91 Pickup 4x4 Xcab sadly sold :(
Bike: 2007 Rocky Mountain Slayer 30
BluYot is offline
Old 05-05-2008, 11:35 AM   #16 (permalink)
Matt16's Avatar
Quote:
I didn't know it pulled up on the the rocker assembly, interesting.
__________________
Toyota FAQ link
Matt16 is offline
Old 05-05-2008, 12:12 PM   #17 (permalink)
Quote:
I'd like to know how that happens considering the studs for the cover are right next to the head bolts.
__________________
Old 05-05-2008, 02:21 PM   #18 (permalink)
both of the above mentioned filters have anti drain back valves. the fram one isnt well made and tends to leak. the anti drain back prevents oil from within the filter draining back into the crankcase while the engine is off, which prevents dry starts. It wont kill the timing chain, or make excess noise, except for the few seconds after startup.
The valve noise/exhaust leak noise are pretty distinctively different from each other. get a long screwdriver, and place the pointy end on the top of the valve cover, and the handle end up to your ear, with the engine running, and you can use it like a stethascope to pinpoint the cause of the noise
MMA_Alex is offline
Old 05-06-2008, 10:29 AM   #19 (permalink)
Matt16's Avatar
I think its injector noise. I loosened off the valve cover to no effect. Is cleaning the injectors difficult? Removing them?
__________________
Toyota FAQ link
Matt16 is offline
Old 05-06-2008, 11:38 AM   #20 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
if that's what you're suspecting, mine made more noise after removing and cleaning them, lol. probably because I removed 1/8th inch of dried up mud off of each which was sort of suppressing the noise in the beginning I guess.
iamsuperbleeder is online now
Tags
klx110, noise, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Persistent Starter Problems on 98 4Runner elburritobandito 95.5-2004 Tacomas & 96-2002 4Runners 16 03-02-2008 07:50 PM
93 22RE loud valve noise timk2915 86-95 Trucks & 4Runners 4 06-28-2007 10:00 AM
22re valve lifter noise question mochester 86-95 Trucks & 4Runners 11 03-28-2007 04:09 PM
persistent virus Churnd Off Topic Talk 2 09-16-2003 12:45 PM
2009 InternetBrands, Inc.
