Performance Products For '01 3.4L Supercharged
Old 08-15-2007, 08:53 PM
4banger444's Avatar
I was just wondering what kind of products are out there for a 3.4L supercharged. I already got custom intake, and exhaust. I Think it makes about 270+hp(ooo ya its in an 88 4runner, it already hauls but you can never go wrong with more)I got 4.88 gears running 35's so couldnt hurt to have a lil more torque even tho im told this engine makes its power down low. Thanks for the help
Old 08-16-2007, 07:31 AM
X-AWDriver's Avatar
If it's not in a 3rd gen then pics need to be seen since that is quite a rarity.
Old 08-16-2007, 07:39 AM
mt_goat's Avatar
Here's a lot of tricks:
http://www.urdusa.com/
But the first thing I'd do is make sure you have plenty of cooling capacity, that's my problem right now:
https://www.yotatech.com/forums/f116...started-82145/
Old 08-16-2007, 07:46 AM
tc
tc's Avatar
7th injector, bigger injectors, fuel mods, wideband O2 ...
Old 08-16-2007, 07:51 PM
4banger444's Avatar
Whats a good idea on how to increase my cooling Capacity?
Old 08-17-2007, 03:52 AM
mt_goat's Avatar
When I find a way I'll post it in this thread: https://www.yotatech.com/forums/f116...started-82145/
What temps are you running now? If you don't know either get a OBDII scanner or an aftermarket temp gauge, My factory temp gauge doesn't start to budge from the middle of its range until it gets over 235 degrees F.
If you haven't already, you should address fuel and timing mods too. If you haven't done those remove the SCer before you do damage to the engine.
Here's a guy that's doing a good job with installing a SCer too:
https://www.yotatech.com/forums/f2/s...thread-111739/
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
anniesball
10
09-15-2015 05:41 PM
anniesball
09-09-2015 09:55 AM
anniesball
09-07-2015 11:20 AM
Quick Reply: Performance Products For '01 3.4L Supercharged
