Peeling off stock 4Runner pinstripe
Old 09-24-2008, 08:21 AM
mmcpeck's Avatar
Gonna peel off the stupid looking stock pistripe off my 2nd Gen 4Runner, any advise? Should I heat it with a hair dryer or use some kind of solvent or just go ahead and peel it off?
Thanks.
Old 09-24-2008, 08:23 AM
littlecommando's Avatar
just use a heat gun and something to scrape it off, but your going to have to paint it after your done, because the paint will be a little different under the stripe because of sun and whatnot
jsn_stockard's Avatar
Heat gun is how I pulled the stripe off of my truck, just take cape not to over heat the paint or it might blister and peel.
Old 09-24-2008, 08:32 AM
lovetharunner's Avatar
I used this DIY for my 4runner:
https://www.yotatech.com/forums/f2/h...pics-56k-70756
Much easier/cleaner than using a heat gun IMO.
What color is your truck? Mine is a black 94' and I didn't have any problems with fading paint.
Let me know if you want any pictures.
Old 09-24-2008, 11:08 AM
highway's Avatar
I used a heat gun to remove the factory stripes, it did go to the metal and primer in a few spots but i was getting ready to paint the whole truck anyway.
highway
Old 09-24-2008, 11:26 AM
Ardent's Avatar
The 3M Rubber Eraser wheel does a great job if the striping isn't dried out and cracking. Super easy and with my Black 4Runner, there was very little paint fade.
The passenger side of my 4Runner looks great w/ no striping... The driver's side however...
Old 09-24-2008, 11:30 AM
M threezy's Avatar
What do you recommend for something that is dry? I pulled off chrome paneling and it left double side foam tape. It is all dried and caked on.
What method should I use?
Old 09-24-2008, 12:01 PM
i would sand it off and paint it, but thats just me
Old 09-24-2008, 01:05 PM
mmcpeck's Avatar
Yeah figured I would use a hair dryer as not to over heat the paint. I am gonna compund the whole truck because I figured the paint underneath the stripe is gonna look different so will try compounding to blend it in.
lovetharunner.....I have a black '91, so I was expecting some fading, but it doesn't look too bad compared to the door jams. Some pics would be great. That 3M Eraser looks sick, I think I may go to Napa and grab one of those, looks easy, and I don't want to deal with any paint blistering or removal at all.
Thanks for that.
Old 09-24-2008, 01:26 PM
mnmontana's Avatar
I used nail polish remover on mine... came out a LOT better than I had expected. But if you care about the paint underneath... I wouldnt recommend it. I am eventually getting a paint job any way.
Old 09-24-2008, 03:36 PM
surf4runner's Avatar
goo-gone and a plastic scaper (=old CC works OK)
Old 09-24-2008, 03:43 PM
mudbogger92's Avatar
I used a 3M eraser that hooked up to my drill! It worked very good on my black 4Runner.
Old 09-25-2008, 10:51 AM
Here are pictures as requested:
Once again: I used the 3M Pinstripe Removal Wheel. It was clean, quick, and did not hurt the paint AT ALL. My 4Runner is a 94' and I did not see any paint fade. The only difference was that the paint under my old stripe did not have any scatches
Old 09-25-2008, 11:53 AM
space-junk's Avatar
i wanna take mine off too, but i actually like my graphics, and wanna get an exact replacement set... any idea of where to find those??
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
crashburnoveride
07-10-2015 06:39 AM
garagespace
07-09-2015 08:37 AM
musashi86
California SoCal
07-07-2015 03:31 AM
Quick Reply: Peeling off stock 4Runner pinstripe
