Peeling film on new 3.0 headgaskets
Replacing head gaskets on a 90 runner after valve job. I ordered an Evergreen gasket set the head gaskets had this plastic like film on the metal portion of the gasket that was peeling off. So I decided to get a DNJ set that was recommended, this one is the same too. Is this normal? What is it? What the hell? I've done lots of head gaskets and have never seen this before.
Any thoughts?
closeup
overall view
Thanks!
Any thoughts?
closeup
overall view
Thanks!
I don't know what to say about that. Flakey for sure.
The only head gaskets I will use are Genuine Toyota, or Ishino Stone brand, both made in Japan.
I'm pretty sure that both the Evergreen and the DNJ are Chinese slave labor goods.
Any good link to these gasket sets? In the past I ordered from Engnbldr, he supplied me with Rock auto brand. I'm talking with them now to find out if there gaskets have this problem. Sounds like Rock auto is now DNJ, and who knows what it is now.
Below are a couple links I pull out of old posts earlier tonight. Not clear what is includes in the set.
https://parts.camelbacktoyota.com/pa...20GASKET%20SET
http://parts.olathetoyota.com/oe-toyota/0411135360
Just noticed one of the links in my previous post is for a 4 cyl. The below might me more appropriate.
http://parts.olathetoyota.com/toyota...me=head-gasket
http://parts.olathetoyota.com/toyota...aul-gasket-set
Thank you for the links. The local dealership changed owners here and I can't stand the new place, so I try not to do business there if I don't have to. Currently weighing my options. Thinking about copper coating the gaskets and using. Engnbldr said the gaskets should be fine to use.
Whatever gaskets you use, DO NOT dope them with Coppercoat, or anything else.
Gasket shellac and Coppercoat, and other similar stuff was OK for engines where both the head and block were iron, but aluminum head/iron block composite engines are another ball 'o wax.
Head gaskets on these engines rely on what is basicly controlled slippage and elastic clamping force from the head bolts, to enable long life in the face of very different coefficients of thermal expansion between the head and block.
Both the block deck and the face of the head should be thoroughly degreased with acetone and the new head gasket installed clean and dry.
Doping them will hurt reliability, not help.
As others have said, get the best you can buy, spending a few more bucks beats doing the work over.
The following users liked this post:
TNyota (09-18-2020)
Are these oem Japanese gaskets manufacturered with the plate facing the head? Seems most new gaskets, and even Engnbldr says they're made with the plate towards the block.
Not sure if they make them for the 3.0, but maybe look into a Victor Reinz headgasket if you arent going to get Toyota brand. I just put a Victor Reinz MLS headgasket on my 5vz rebuild and it was very nice.
Thanks for assistance, my block surface wouldn't work with a metal gasket. I've been going back and forth with Engnbldr and his son about these gaskets (DNJ) he say's as long as I clean and prep the surfaces good, these gaskets should be fine. They've sold countless kits and haven't had any issues with the DNJ gaskets.
Any thoughts?
closeup
overall view
Thanks!
Any thoughts?
closeup
overall view
Thanks!
It's very thin, and very brittle. It doesn't really peels off, it's more of a flaking off and like I said it's extremely thin. I don't know if it's plastic or not, could be some kind of material that gets soft as it heats to adhere better. I don't know... Ted at Engnbldr said it would work fine. Gonna try it, it's going on a runner that gets little use anyway. I just need it running to hold me over till I can find a good deal on 2010ish Taco.
