PCV Valve
Old 05-29-2008, 12:16 PM
4x4phil's Avatar
PCV Valve
I need some help!
I had a pcv valve that was stuck solid in my 90 3.0 forever.
I finally got the stupid thing out last night, but I can not get the stupid new one back in it's place.
I can get the gromet in just fine, I can put the valve in the gromet no problem, just can't find a way to get both in there. I tryed to put both together out side and put it in, but it is a PITA and i have tryed putting the gromet in first, then the valve, once again no dice.
I know it's a tight space, (I have the skinned knukles and fingers to prove it)
I was wondering if anyone knew a trick, or something to help me out on this problem?
I want to take my boat out to the lake, we leave tonight, but I can't drive with out the stupid valve....
HELP ME...... PLEASE!!!!
Old 05-29-2008, 12:30 PM
qdude79's Avatar
Have you tried lubing the valve and/or grommet to shoehorn it in?
Old 05-29-2008, 12:56 PM
4x4phil's Avatar
ya I tryed that, tryed pliers, pushing it in.
I think the biggest problem is there is no room to get your hands or tools in there.
What a stupid ass place for that valve.
Old 05-29-2008, 01:04 PM
Guest
seanz0rz's Avatar
make room... the 10-15 minutes it takes to remove the upper intake tract will save you hours of headaches.
ive found using some fresh motor oil around the bottom of the valve allows it to slip in easily.
also, are you sure you have the proper size?
Old 05-29-2008, 01:16 PM
4x4phil's Avatar
I hope I have the right size.....it looks like the exact same size as the old one.
I didn't think it was that easy to remove the intake......I might look at that.
Thanks!
Old 05-29-2008, 02:08 PM
scuba's Avatar
i just used the heavy side of my vice grips to kinda bang it in there
ghetto i know, but it worked
Old 05-29-2008, 08:48 PM
abecedarian's Avatar
put the grommet in, then place the PCV on the grommet, then place a piece of hardwood dowel rod on top of the PCV and smack the wood with a hammer.
No need to damage the flare on the PCV with a hammer now, is there?
Old 05-29-2008, 09:21 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yeah...that's a great trick, Kirk. I've done that a zillion times with different jobs using different tools.....pliers, wood, and whatnot. You just need that sudden impact to jolt the PCV valve in there.
Might make sure you can get the hose onto the PCV easily before you get the valve stuck in. Otherwise, put the hose on the valve first, use some long pliers....needle nose, channel locks, linesman etc....and hold the valve where the hose connects. Then, just smack the pliers.
BTW, I believe it'll take more than 15min's to get the intake plenum off. You have a gasket to deal with that will probably tear on you. Then what are you going to do?
Old 05-30-2008, 10:08 AM
wardriver's Avatar
Obligatory PCV not PVC comment.
Positive Crankcase Ventilation not to be confused with PolyVinyl Chloride
Old 05-30-2008, 11:55 AM
thook's Avatar
Sure, sure.....so I spelled it wrong. Simply a typing error.
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: PCV Valve
