Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
passenger side noise after turning engine off, 2nd gen
after I turn my engine off, there is a noise in the passenger side dash, behind the glovebox/near the vents, sounds like a motor wheezing to a halt, it sometimes goes for as long as 10-15 seconds. Any idea what this might be/solutions?
__________________
92 4runner,Thorley Ceramic Headers,Stan's Custom Exhaust,OME Suspension,DowneyHDCoils,MarlinHD Clutch,PIAA520s,24/30"Magnaflow Muf/Cat,Warn Hubs,BudBuilt IFS Skid+Xmbr,Sonoran Truss,Odyssey Batt,33x10.5 BFG A/T,ISR Mod,Boyle's Alternator,TJM T-15,Demello Sliders,Warn XD9000,Dual 4.88 Truetracs,LCE bored TB,Weasy Cams,NWMP Xtnd Range Tank |
| Sponsored Links |
#2 (permalink) |
That's what my power antenna does. Have you considered that?
__________________
1990 4runner-- stock, yet it's my baby! |
#3 (permalink) |
are you running the A/C?
__________________
1986 monte carlo ss LT1 swap "Latest News: I found out Im the mailmans son." |
#5 (permalink) |
noise after engine turns off in 2nd gen
those 3 questions are excellent. YES- could be the power antenna,
I DO sometimes run the A/C (but this happens even when I am not using the A/C), and IS coming from the same area as the charcoal canister. How can I pinpoint which one it is? The power antenna is all the way down (I do not have it up, as the motor has gone out on it)...it no longer moves. I recharged the A/C myself...but have not replaced the compressor. I DID have my wife start and stop the vehicle...with my head in the engine bay...I did not see any parts moving in the bay to create this sound...seemed to be coming from INSIDE the console...but canister..could be...or antenna...these are great suggestions! I would love to get rid of this noise. after turning engine off it does not sound very healthy! does canister make noise? why, and how to verify/fix this? antenna...any way to fix or turn off this function a/c how to quiet down compressor/verify? (A/c works great) thanks a lot
__________________
#6 (permalink) |
well if your hearing it after you haven't used the a/c than thast not it ,sometimes the freon makes a hissing noise after you shut the engine down if your useing a/c ,not applicable if it wasn't on though, could be the canister venting ,try looseing the gas cap ,and the shut it down and see how that does.
__________________
#7 (permalink) |
Sometimes vents & directors inside the air duct system are vacuum-actuated and they can cause this sounds as the vacuum releases...my $.02 worth.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 2006 Taco 17" Alloys, 224k miles, AISIN Hub Swap Kenwood Double-DIN Head Unit, 1x 290 watt Kenwood Amp driving 2 Klipsch speakers, 1x Kenwood 1000 watt sub amp driving 2x10" Infinity Perfect 10.1D subs |
#8 (permalink) |
it's the antenna!
It's the antenna! Got the problem wheezing motor sound to turn on when I turned on the radio...and switched from CD-Tuner...it is definitely the sound of the antenna motor trying to raise and lower the antenna. Seeing as my antenna is stuck in the down position, it's straining, hence the noise.
I hardly use the radio, mostly use cds and may even go with XM radio in the future....is there any way to disable the antenna motor, remove a fuse, or coupling etc? thanks! getting to the bottom of this! T
__________________
#9 (permalink) |
If you are so inclined, you can cut and cap the wire from the back of the stereo. I think there are two wires, but you should probably consult the FSM just for safety.
__________________
1990 4runner-- stock, yet it's my baby! Last edited by myfinalcoffin : 07-06-2006 at 01:42 AM. |
#10 (permalink) |
disabling power antenna in 2nd gen
is there another way to disable the power antenna in a 2nd gen rather than taking the stereo out and cutting the cable? I would really prefer a fuse removal or different fix than taking out the stereo
or- maybe if I just fixed the power antenna that would be a better option. I will search for 2nd gen antenna fix parts/threads now!
__________________
#11 (permalink) |
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#12 (permalink) |
Yeah... This is an old thread, but just to close it off properly, here's how to disable your power antenna motor:
1. Take the plastic trim piece off the inside of the passenger side wheel well (actually, just take enough screws off so that you can pull out the rear end of the trim piece to see behind it.) 2. Look up behind the trim piece to see the power antenna and motor. There are two wires going from the assembly... the antenna wire that goes to the radio, and the power wire. Disconnect the connector for the power wire (just going by memory, the connector is probably 7 or 8 inches away from the motor. 3. Re-install the plastic trim piece. Done! No more whiny motor noise! EDIT: For some pics, check out Bob's writeup here.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold Last edited by GSGALLANT : 08-24-2006 at 09:20 AM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help! Crazy pre-warm up noise from engine passenger side | esoterik | 86-95 Trucks & 4Runners | 7 | 05-04-2007 02:42 PM |
| passenger side dome light button broken 2nd gen | taikowaza | 86-95 Trucks & 4Runners | 3 | 02-22-2007 01:28 PM |
| Noise from front passenger wheel assembly when turning around in a driveway | niseguy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-21-2006 09:00 AM |
| Brakes Pulling To Passenger Side, 2nd gen 4runner | jsnby | 86-95 Trucks & 4Runners | 5 | 12-20-2005 08:23 AM |
| 2nd gen Passenger side CV joint | tc | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 11-12-2005 04:37 PM |
