Passenger Rear upper link, install help needed.
Old 02-02-2012, 09:28 AM
LifterCatcher's Avatar
Hey everyone,
finally getting around to lifting the 4runner and I am almost done. I had to remove the passenger rear upper link to allow the axle to pivot enough to get the new springs in and now I cannot get the link installed again.
I removed the link at the axle & cannot for the life of me get the link mount/bushing and were it mounts to the axle lined up to put the bolt back in? it's about an eight of an inch off and I dont want to beat it in with a hammer because of fear of messing up the threads on the bolt.
It is this mount in the picture
Does anyone have any ideas?
Thanks
Chris
Old 02-02-2012, 07:43 PM
bmcghie's Avatar
You're not talking about the track bar, yes? That keeps the axel centered left to right? If it is that one... get a buddy and have him push the truck while the axel is slightly weighted.
If it's actually the upper link... maybe get the axel under a bit of weight, and then try using a prybar through that hole in the mount to tilt it forwards or backwards to get the bolt to line up?
Either way, I think you need a helper!
lledwod
08-30-2016 01:03 PM
coryc85
09-09-2015 06:24 AM
icentropy
07-11-2015 07:21 AM
ItsJustD
07-07-2015 07:49 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Passenger Rear upper link, install help needed.
