| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Parts identification, Transfer case & Idler arm
#2 (permalink) |
That case to me looks like a gear case for a lake 80's (my 88 looks like that) 4 cylinder Yota. That is the single shift style where the gear and transfer leavers come through one hole in the trans, probebly a W56 trans.
__________________
BRAKE LINE NUTS $1 each !!!!!!!(min 10) PLASTIC COATED BRAKE LINE $1.50/foot Coated Front brake lines with nuts $10 each 95 22re extra cab, custom box, 4:56, 31inch tires, electric fan, Flat black paint, 4 runner buckets and mirrors WANTED: aussie or lockright in CANADA!!! |
#4 (permalink) | |
well, flash tried, but with your small picture and absolutely no id numbers from the tcase, its kinda hard to give you any info...
also, the first part of your post is very confusing, so try breaking the sentences up and giving a lil more detail...
__________________
Trailer Re-Build - Check it out!!! Quote:
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack |
#5 (permalink) |
Mate there is nothing confusing about the first paragraph, it has punctuation as necessary. If you let me know what your English is getting stuck on and ill try translate for you. I also see you are a long member of the forum which then puzzles me why you complained about the small image, Your knowledge of this forum should tell you to click on the image and hey presto its a good quality
full size image. Thanks |
#6 (permalink) |
Wow, with that type of attitude, good luck on getting the info you need. I was gonna help you out, but now... well forget about it.. mate....
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it |
#7 (permalink) |
There is no attitude, i was getting grilled for not making sense and posting a ty picture. What am i suppose to do, just lie and agree that it it makes no sense and the image is bad quality?
I'm confused. I didn't realize this was a grilling forum. My apologies if that offended and thin skinned people. |
#8 (permalink) | ||
First off, i wasnt grilling you, but now its fair game... this is what i dont understand Quote:
but even when you click that button, the image is relatively small... hard to see detail... i was just trying to give you tips to help you get some more info... sorry for trying to help... Mate...
__________________
1990 4RUNNER
#9 (permalink) |
again my deepest apoligies.
Ill try rephrase the sentance. I own a Toyota 4runner 1991, it used to have a 3vze engine and a 5 speed manual transmission. I removed both the engine and transmission and converted to a Australian Holden Commodore VP V6 engine and a Th700 4 speed automotic transmission. The transfer case from the original engine was removed as the conversion i made i received a transfer case already attached to the th700 including the adapter to it. The only problem is the transfer case is leaking oil badly and need seals / gaskets replaced but i cant be without the car, so i figured it would be best to buy another transfer the same as the one on now and clean that up and swap them over. The problem is i don't know any information about it. i cant see any numbers on it either. unless im blind. I will try to upload the original photo somewhere to make it easier for people to see. |
#10 (permalink) |
Like I said, late 80's Toyota 4cylinder Gear case that was connected to a W56 trans. You guys are like a bunch of hens.......
__________________
BRAKE LINE NUTS $1 each !!!!!!!(min 10) PLASTIC COATED BRAKE LINE $1.50/foot Coated Front brake lines with nuts $10 each 95 22re extra cab, custom box, 4:56, 31inch tires, electric fan, Flat black paint, 4 runner buckets and mirrors WANTED: aussie or lockright in CANADA!!! Last edited by Flash319; 11-04-2008 at 06:38 AM. |
#11 (permalink) |
Based on what Flash319 said and this chart - http://4x4wire.com/toyota/faq/parts/
Im going to say it is a RF1A
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap (R150F)~SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5 Pro Comp M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~Marlin Crawler Rear~Addicted Offroad Front Bumper~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
| Tags |
| 45496, 4runner, 91, 96, case, cases, gasket, identification, idler, leak, numbers, part, parts, pics, toyota, transfer |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transmission & Transfer Case Identification Help | 4wheeling | 86-95 Trucks & 4Runners | 4 | 10-21-2008 11:32 PM |
| Idler Arm Identification | RustBucket | 86-95 Trucks & 4Runners | 7 | 05-11-2007 05:55 AM |
| Pitman & Idler Arm | mastacox | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 01-12-2005 05:36 AM |
| Will Worn Pitman & Idler Arm Making Driving Dangerous? | 1fly | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-16-2003 06:21 PM |
| Transfer case identification | az4x4runner | Offroad Tech | 3 | 10-06-2003 01:24 PM |
