Part# for 1986 auto transfer case same as manual?
Old 03-04-2011, 03:17 PM
Thecarlessdriven's Avatar
Title says it all. Are they the same?
Thanks
Frank
Old 03-04-2011, 05:33 PM
Fossilized
Staff
dropzone's Avatar
yes it should be the same however it could be a top shift or forward shift.
Don't know for sure so I gonna forward your question to our resident Auto trans expert Dirtco
Old 03-04-2011, 05:49 PM
Thanks man!
Old 03-04-2011, 06:04 PM
R.DesJardin's Avatar
t-cases
If I was going to guess I would say they are different as far as swapping them. The auto t-cases (A340H) share oil with the trans and are just their own animal. I just picked one up for spare trans parts. Also I think the 4wd controls are electric. The later ones have a forward shift chain drive case. I haven't seen or heard of a gear drive behind an auto from the factory.
Old 03-04-2011, 10:14 PM
Numbchux's Avatar
I think it'll depend on the transmission. My '87 22RTE 4runner had an A340H transmission, and the tcase was integrated into the trans, and very different than the RF1A tcase that was in my '86 parts 4runner.
Here's a good page with some info on transmissions and tcases (although not 100% correct, as my A340H was an '87 22RTE without ADD...)
http://www.4x4wire.com/toyota/faq/parts/
Old 03-04-2011, 11:16 PM
Fossilized
Staff
dropzone's Avatar
knew some of you auto guys would chime in...i honestly wasn't sure
Old 03-06-2011, 03:43 PM
DIRTCO's Avatar
They are differant. The automatic has a transfer case that is chain driven and is part of the transmission, it shares fluid with the transmission and the transmission park pawl is located inside the transfer case. The transfer case is like a mini automatic transmission with clutches, etc. The manual transfer case is gear driven and a seperate stand alone unit, you can also install lowre gears, twin stick, dual cases, etc. The only way you can swap transfer cases is to install a gear driven manual transfer case behind the auto with this adapter. http://www.inchwormgear.com/store/pr...products_id=86
I have a lot more information in my 86 Turbo 4Runner build thread, the link is below in my build thread.
Old 03-06-2011, 04:17 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
ALL A.T's ALL ADD's And ALL V6's have a chain drive.
ALL R/E 4 & 5 speeds EXCEPT for the ADD trucks have gear driven TC's.
There are TWO AT's. The A340f and A340H. The H is a POS.
blah... http://www.pirate4x4.com/forum/showthread.php?t=587521
Old 03-07-2011, 09:59 PM
Thanks for all the help guys!
Now is there a cable/wire diagram I could use? Trying to figure out what this cable near the oil pan is.
Thanks!
Old 03-09-2011, 03:47 PM
4runnerx3's Avatar
Inside of auto transfer case.
nanhodges2733
05-29-2020 03:28 PM
Tykiller1994
08-10-2015 07:49 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Part# for 1986 auto transfer case same as manual?
