YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-21-2009, 12:22 PM   #1 (permalink)
Personal Sales Rating: (0)
isaac338's Avatar
parking brake parts diagram?
My parking brake cable just snapped, and the handle inside the cab came right out of the dash (it's sitting on the floor now).
Does anyone have a link for a blowup diagram of the parking brake assembly so I can see if it's fixable or if I should just get an entire assembly off a junker?
Thanks
__________________
1994 Xtracab pickup, 180,000km
1987 4Runner, 510,000km
isaac338 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-21-2009, 12:32 PM   #2 (permalink)
leebee's Avatar
look under the dash to see if the cable/barrel is the culprit. next spot is the pivot point under the passenger seat area of the frame. most likely a front cable assy, not too expensive but a pita if you have to work outside in the cold!
lee
__________________
93 sr5 v6 auto, 4x4
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 02-21-2009, 01:00 PM   #3 (permalink)
Threadstarter [OP]
isaac338's Avatar
Quote:
lee
It's broken at the pivot on the frame rail. I just want to see how the assembly in the cab is put together so I know whether it's worth fixing.
__________________
isaac338 is offline
Old 02-22-2009, 08:27 AM   #4 (permalink)
leebee's Avatar
there are two clips on top of the trans on the firewall that you have to open to remove the old cable. right under the dash where the p/brake handle is located, on the top of the rod is located a pawl that you have to release for the handle to be able to retract to get at the barrel end of the cable.
take a look in one of the links at the top of the page of the fsm. it should detail the r&r sufficiently, hope you have small hands or a b/l as it is pretty tight between the top of the trans and firewall. i would rate it a 2 banana job, more time consuming than difficult. there are some sharp edges so take your time.
lee
ps
while you have things apart, shoot some lube into the cable housings, lube all the pivot points and you might as well check the rear brakes for proper adjustment. kind of crappy weather to do it in unless you have a garage! good luck, keep us posted.
lee
__________________
93 sr5 v6 auto, 4x4
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 02-22-2009, 08:50 AM   #5 (permalink)
Mine snapped a few months ago. I have yet to order the new cable, but I'm in the same situation. Waiting for warmer weather to install and buy another one.
__________________
1989 Toyota pickup 4x4 - 22re - Stock
DupermanDave is offline
Old 02-22-2009, 08:57 AM   #6 (permalink)
874runnersr5's Avatar
Click the image to open in full size.
__________________
87' 4runner Sr5 :Little lift, bumpers to bash junk, and more jeeunk in my build thread -sold
874runnersr5 is offline
Old 02-22-2009, 09:16 AM   #7 (permalink)
turborich's Avatar
Mine snapped right where the cable meets the little aluminum end (like on a bicycle brake cable) Anyways, the cable wasn't offered aftermarket anywhere (dealer only) so I went to the pic a part & simply cut the end off of a cable & picked up some cable clamps. Then put it back together. It works fine now. I would have gotten the entire cable from the pic a part but I saw that the various years & models had different mounting brackets at the backing plates.
Just an idea.
turborich is offline
Old 02-22-2009, 10:23 AM   #8 (permalink)
Threadstarter [OP]
isaac338's Avatar
Quote:
Just an idea.
That's a good idea - I've got some cable clamps kicking around and it's broken pretty cleanly. Thanks.
Is there anything that prevents the handle from coming completely out of the housing if the cable isn't attached? The diagram shows the handle inside the housing :/
__________________
isaac338 is offline
Old 02-22-2009, 10:56 AM   #9 (permalink)
Just an idea.
Does sound like a good idea, though I'd still feel safer (personally) replacing the cable entirely. This cable has lasted this truck 20+ years, I'm sure a replacement cable will do just as good. Though, who knows, maybe your replacement idea might make it last 30 years. You can only try and find out.
__________________
Yotatech
4WD Truck
Paid Advertisement
Tags
1989, 1994, assembly, brake, cable, diagram, diagram92, dirgram, ebrake, parking, parts, pickup, replace, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hooking Up Parking Brake On Disk Brake Swap Johannes 84-85 Trucks & 4Runners 14 11-06-2009 10:02 AM
parking brake cosmo 95.5-2004 Tacomas & 96-2002 4Runners 5 04-30-2008 08:13 AM
parking brake andrew241 86-95 Trucks & 4Runners 6 06-27-2007 05:22 PM
All Pro Rear Disc Brake Kit removes parking brake! RunnerUp 95.5-2004 Tacomas & 96-2002 4Runners 12 09-28-2006 12:26 PM
new parking brake 4runner4ever 95.5-2004 Tacomas & 96-2002 4Runners 1 11-13-2004 01:52 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
