Park brake cables
Park brake cables
My 86 toyota pickup xtra cab was missing the rear brake cables when I bought it so now I'm having to search for them and can't seem to find any luck. Just seeing if any one has a link or knows where I can find them so I can use the park brake instead of having to leave it in gear and shut it off every time I have to get out even for just a minute..
You searched for them? Where?
http://parts.lakelandtoyota.com/show...rimLevel=18292
About $70 each. Use your VIN to be sure you get the right part; "xtra cab" isn't enough.
This is part of the cable the goes to the back brakes from this bracket. As you can see it was cut for some reason so i need to get them replaced and i should be good.
Found a front cable on amazon and turned out to be too short.. it was for a standard cab. It did not state or give a choice of whether it was for a extended cab or regular.. so now I got to send it back. My front brake cable also has the end on it with the hole for the pin to go through. Can find the cables with the same ends on it all day long but not the one with the hole for the pin..
alva22re
02-20-2016 04:21 PM
