YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 09-12-2007, 07:45 AM   #1 (permalink)
Personal Sales Rating: (0)
Djlarroc's Avatar
Painting truck a different color....
Ok, so with all these incredible "roll jobs" I've been seeing and after reading Tortis' thread, I've decided to paint the rig. My question: How dumb is it for me to paint the truck a different color? It's currently re... er pinkish. I was thinking , if I'm gona paint it, I might as well change it up and do a different color, but then, how hard is it to get the door jams, under hood, between all the moldings, etc, etc, etc. Should I just go with the red again?
Djlarroc is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 09-12-2007, 07:51 AM   #2 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
Quote:
Well that depends on how fussy you want to be. If it was me and I really wanted a different color, I would take the time and do it. If you want the easy way out, go with red again as this will make it alot easer on you. Have the though of maby a 2 tone like black and red. This way you can keep the existing jams and stuff the same color. Just my 2 cents.
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 09-12-2007, 08:22 AM   #3 (permalink)
two tone is not a bad idea. also keep the interior color in mind.
i would go a dark burgondy that way the jams/hood/etc would not have to be painted and not stick out so much when open. i painted my 85 black and it was silver originaly on gray interior and it looks fine.
michalik_piotr is offline
Old 09-12-2007, 08:45 AM   #4 (permalink)
Toyvana's Avatar
I was in the same boat back in 2003. My red truck was really turning pink and in need of a paint job. I really would've like to painted it all black, but I knew it would be a task to paint the inside of the cab to match. I comprimised and went with a two tone and it worked out great.
Before
Click the image to open in full size.
After
Toyvana is offline
Old 09-12-2007, 09:27 AM   #5 (permalink)
Threadstarter [OP]
Djlarroc's Avatar
Nice!! Ya, I was thinking of the two-tone as well. Maybe Red & Silver or black. The interior is gray so I have almost all the options in the world haha. I am just trying to get a feel for how difficult and pain in the @ss it will be to have to do the jams etc. Actually the jams don't seem that bad, it's underneath the hood. I have to top off the the Runner now, so painting the bed should be easy. I just hate to see cars painted another color and still show the prior color on jams and hoods.
Djlarroc is offline
Old 09-12-2007, 09:41 AM   #6 (permalink)
I have sort of the same problem; the runner I got recently was originally painted brown, but somewhere along the line a previous owner painted the outside black. The interior is still tan, and door jams/under the hood are brown (though under the hood has a little more black thanks to the grime). Also, I recently got some seats from a '90 runner that are blue. So, the truck is in an ugly stage now: black outside, brown door jams, tan interior, blue seats. I'm going to end up taking all of the interior out, taking off all of the paint in various colors, and re-painting the whole thing black. I'll probably get some seat covers, but I have to decide if I'll be replacing the interior with something other than tan first, and if so, how much it'll cost me to get all new plastic molding and carpet in matching colors.
mith is offline
Old 09-12-2007, 11:15 AM   #7 (permalink)
tj884Rdlx's Avatar
spraying door jams isn't that big a project. are you spraying the paint? if not, at least do the strip down of trim and hardware yourself, which will save you loot and you'll know its done right.
remove the interior door panel, remove the window & hardware, seals, and gaskets. if they're brittle, you can buy replacements, or just "rehydrate" them with armor all. a few sessions of good misting and they will soften up and turn black like almost new, and come out easier. (you can bathe them in armor all knowing you'll be treating the whole vehicle with paint prep solution before the paint flies.) pull the door handles off on the outside, and anything else in the jam you want original you can then tape off with good masking tape (like VIN tags).
for a good "original" look, you'll need to pull the bed cap too, so you or your shop will then use plastic (drop cloths) to tape off the interior at the door openings and cap opening.
pull as much trim as you can to reduce what must be taped. then you can plastic and tape just major components, like your radiator, windshield, etc. spray whatever you can flat black first, like wheel wells, (give it time to dry) so you have good taping surfaces to outline your new color at the body's edges.
the hard part is the engine bay. if you dont mind a red bay, then just cover the entire motor with plastic, tape to the fender bolt strips for a nice straight line. otherwise you'll be removing off the firewall and laying it forward before covering with plastic. you may be better off doing some crafty spray with flat black and a straight-edge spray guard (cardboard) instead.
i've been having this same debate with my own red (pink) runner too. its been resprayed once and the cheap paint is fading worse than the original underneath. i've drawn up some schemes using toyota racing colors when considering keeping the jams red. check out my pic below for some ideas you're welcome to pirate.
here's a good link on self-painting: http://www.eastwoodco.com/jump.jsp?i...8&iSubCat=1436
good luck!
tj884Rdlx is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
blue, color, colored, colors, door, hood, ideas, interior, jams, multiple, paint, painting, powered, toyota, truck, trucks, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Painting the wheels with Dupli color wheel paint? outlaw27 95.5-2004 Tacomas & 96-2002 4Runners 30 10-30-2008 07:35 AM
Painting shackles - what paint and what color? HaveBlue General Vehicle Related Topics (Non Year Related) 18 01-22-2007 04:45 PM
Painting hood - What color? 4x4Travis 86-95 Trucks & 4Runners 23 01-01-2007 06:36 PM
Painting over two-tone. Do I color sand now? FilthyRich Maintenance & Repair Archives 2 04-01-2005 03:56 AM
Just finished painting my truck Memphis_Yota 95.5-2004 Tacomas & 96-2002 4Runners 12 10-04-2004 08:27 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
