P/S left....Manual to the right - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-24-2007, 03:25 PM   #1 (permalink)
Bigblock's Avatar
Judging by the search engine I'm the only one that has this problem.Turning left is easy" POWER steering!" Turning right takes much more effort but will finally assist.I know it's just a valve in the steering head but how do you fix it?I know nothing about steering haeds.Lucas didnt help.Flushing it was expensive and didnt help.2 out of 3 of my Toyotas do this.A new head is about $1200!Any ideas?
Bigblock is offline
Old 01-24-2007, 06:55 PM   #2 (permalink)
Bigblock's Avatar
Anybody
Bigblock is offline
Old 01-24-2007, 07:12 PM   #3 (permalink)
PoleVaulter95's Avatar
i dont know anything about power steering but if it is good left then possible a hose or something is clogged for it to turn right? that could be completely off but its an idea
__________________
95 4runner 3.0 auto downey torsion bars and hd springs 32 khumos and way to much spray paint
PoleVaulter95 is offline
Old 01-25-2007, 04:54 AM   #4 (permalink)
GSGALLANT's Avatar
A problem with your rotary valve sounds likely.
For future reference, you can do the fluid flush yourself, for the cost of a couple of bottles of ATF. See my writeup here.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 01-29-2007, 06:24 PM   #5 (permalink)
Bigblock's Avatar
Well, I figured it out. I went and bought a new steering head, put it on, and it did the same thing. Then I discovered a bleeder screw on the steering head. So when I bleed all the air out, it was fixed. BTW, NAPA has remans for $300+/-.
Bigblock is offline
Old 01-29-2007, 06:36 PM   #6 (permalink)
toyota_mdt_tech's Avatar
Quote:
Dude, sounds just like a worn steering joint. You know, those little ujoints. Check them first. If you dont have a tilt, you might not have any joints. Otherwise, it would be the torsion bar in the steering box which works the spool valve to give you assist on either side of the ball nut. (basically, a steering box)
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
left and right Localmotion 95.5-2004 Tacomas & 96-2002 4Runners 4 01-31-2005 11:53 AM
Repair manual for 99 4runner...3 hours left jdecker 95.5-2004 Tacomas & 96-2002 4Runners 0 01-14-2005 03:05 PM
Owners Manual and Repair Manual? hale 95.5-2004 Tacomas & 96-2002 4Runners 3 06-11-2004 06:45 AM
Does Factory Service Manual = Repair Manual? Roadrunner 95.5-2004 Tacomas & 96-2002 4Runners 18 01-06-2004 07:25 PM
Looking for a 2001 4Runner Repair Manual - Can only find a 2000 Haynes manual Roadrunner 95.5-2004 Tacomas & 96-2002 4Runners 1 04-11-2003 10:47 AM
2009 InternetBrands, Inc.
