overheating after valve cover job??? HELP!!!
Old 10-21-2007, 06:05 PM
MIKEMOKAS's Avatar
hey all...
just got home frome my gf's dads shop where i did my valve cover gaskets...
good news is i dont smell burnt oil..
but bad news is that everything was steaming...
i took the oil cap off and there was steam comming out..
and also steam comming out of the top of the rad...
their was a water drip before i left the shop so i poped the hood and released the pressure at the cap of the rad. so that i could get home...
the drip must be a loose clamp somewhere...?
but the only reason i can see the oil from steaming would be from the new hose i put on the pcv being kinked... that sound right?
a couple mixed up vacuum lines wouldent do this right?
every once in a while i would hear water sizzling, but i couldent figure out where it was comming from...
ill post up my pics and info in my other thread..
thanks for any help.
Old 10-22-2007, 02:43 AM
MIKEMOKAS's Avatar
bump please help!
Old 10-22-2007, 05:15 AM
mt_goat's Avatar
That doesn't sound good. Only one thing comes to mind that would cause that, blown HG.
Old 10-22-2007, 08:10 AM
Blurr's Avatar
have you changed your oil after completing the HG job? maybe it is just boiling off residual coolant?
what I did was add 5 qts when I was finished and immediately drained it before starting it the first time, i wanted the least amount of coolant in the oil passage ways as possible.
check the dipstick for coolant, make sure your coolant levels are good and let it run for 15-20 minutes or so and see what happens.
Old 10-22-2007, 08:14 AM
mt_goat's Avatar
hey all...
He said valve cover gaskets, that shouldn't get coolant in the oil would it?
Old 10-22-2007, 08:35 AM
Blurr's Avatar
oops, me no read good
Old 10-22-2007, 12:11 PM
MIKEMOKAS's Avatar
i dont see any coolant in oil or vise versa... the hg better not of blown!
i dont know where to start... i guess ill check all of the water hoses/ connections that i messed with dureing the valve cover job...
and maby just go and get the correct hose for the pcv?
ttyl
the1998sr5
15
07-14-2020 08:35 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
irritech
07-27-2015 05:15 PM
calderp
07-27-2015 09:58 AM
Quick Reply: overheating after valve cover job??? HELP!!!
