Opinions on 3vze HG Job/Parts list
Old 04-25-2007, 04:11 PM
mike92runnerSR5's Avatar
Okay, so I've decided to have a shop do my new HG for 1st time after recall. Truck has 127K. I'll supply the parts and he will install for $1000. Plus he will give me a 1 yr gaurantee. Head work extra $440+/- from local machine shop (incl. press. test/shave heads, grind valves, install new valve seals, shim/adjust valves) depending what I need. Using all toyota parts except for Topline head bolts. New parts: Valve grind gasket set, timing belt, knock sensor & wire, water pump, radiator + hoses, all belts, O2 sensor, coolant temp. sensor, thermostat, plugs, wires. Parts: $800 +/-. Only other adds might be exhaust system and injector svc. Any thoughts on something I missed would be appreciated. Thanks.
Old 04-25-2007, 04:53 PM
justinking060310's Avatar
distributor O-ring and possibly O-rings associated with your oil cooler
Old 04-25-2007, 04:56 PM
thanks kat..I had the oil cooler gaskets on my list in front of me..just didn't mention..I need to see if their included in my gasket set or not..
Old 04-25-2007, 05:38 PM
olharleyman's Avatar
Correct me if my math is wrong but for $2200 why not 3.4 it???
Old 04-25-2007, 06:13 PM
not sure I could do a 3.4 in my area for that..plus the mods required..I would need about $400-$500 in tools alone to do the work above myself...could save about $150 if I went with enginbldr for the gasket set though instead of the oem. Not sure if engnbldrs set includes all gaskets from block up?
Old 04-25-2007, 06:36 PM
silversup's Avatar
tack in that knock sensor and wire
Old 04-25-2007, 06:37 PM
silversup's Avatar
Ha i cant read. U got it man!
Old 04-25-2007, 06:40 PM
yea..got it...thanks.
Old 04-27-2007, 10:18 AM
TNRabbit's Avatar
FIPG, or Form In Place Gasket material. Can't complete without it!
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
dumpster84
04-30-2016 06:03 AM
Peevedkitten
11
08-31-2015 06:57 PM
Quick Reply: Opinions on 3vze HG Job/Parts list
