Opinion needed - rear oil seal
Old 04-29-2008, 07:58 AM
stupid_mud_gremlins's Avatar
So, it looks like I'll be doing a rear oil seal soon, and my question is what will be easier, remove the transmission, or pull the motor? It's a 3.D'oh, 4 by of course, with A/C which is why I'm thinking of taking the transmission route. Any comments or ideas?
Old 04-29-2008, 08:07 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I'd pull the tranny. Both are pain in the butt jobs, but atleast with the tranny there's less to remove and there's no chance of creating vacuum leaks, breaking fragile stuff, and other junk after reassembly.
Oh, and there's no fluid to drain and refill. You don't "have" to drain the tranny....just makes a bit easier. Less weight.
Old 04-29-2008, 08:10 AM
eric-the-red's Avatar
The transmision is usually easier. It's not too hard a job if you have some mechanical skills. A good tranny jack will help a lot, the transmission and transfer case together are heavy and awkward. It would be a good time to replace the trasnmission input seal, and the clutch of course.
Old 04-29-2008, 08:24 AM
no clutch, it's an auto. But that's a good idea on the input seal. I f I look at it as well, it gives me a chance to do U-joints and the Diff seal too.
voiddweller
19
05-02-2016 09:10 PM
Alaskan91
09-21-2015 04:39 AM
cchinny
06-25-2015 08:11 PM
abalagtas
06-22-2015 12:57 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Opinion needed - rear oil seal
