OME Damper install HELP!(new style)
Apparently they redesigned the OME damper from the one that is written up in the tech section. I go to install it last night, get the bolt side mounted fine, I go to mount the stud side(the same side you had to use the pickleforks to beat out the old stud), get the nut threaded on, and then the stud just spins.
I'm not sure if the stud gets slightly bigger, so you can press it in, then it won't spin, that is an idea I've got. So, does anyone have any tips on getting this new design installed?
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
ripp96
07-25-2015 02:32 PM
MTLroadierunner
07-20-2015 03:07 PM
