Ok stupid Question Here..
Ok guys just ordered a Pacesetter header got it today and i look at the box it says 2whl drive only..... Now i run a 1994 4x4 and order this header cause they said it fit, I don't want to go hook it up f it up and not be able to return it... Any one now for sure if this header fits the 4x4 Part#P40701184 on www.carpartswholesale.com?? Thank in advance sorry for the lame question.
I can not imagine why it would not work on a 4x4 they use the same engines and frames are almost identical. main difference between the 2wd and 4x4 is the suspension and the 2wd dose not have a t-case
Ya i'm thinking the same thing.. The collectors for this header are same as stock though thought the description read 2 1/4 collectors. Now i'm not sure if i want it or my $$ back lol..
Ok called pacesetter. They said it's the wrong one and won't fit due to clearance issues....
Boy do i hate when ppl yes yes yes you on the phone when ordering parts and then send you the wrong sh!!!t. Works out i might not want it now cause of the tubing diameter (Stock Size). Figured i'd let you all know Part#1184 does not fit on a 4x4 #1183 does.
Ya i got them from the above mentioned site which i'll never go to again.. I hate online shopping i want to touch what i'm buying make sure it's what i want you know... Thanks for the info sorry about the rant...
Flying91
45
04-11-2024 04:39 PM
sabine
07-18-2015 03:59 PM
