Oil pump gear question
Old 07-22-2009, 07:49 PM
olharleyman's Avatar
I can not seem to find any info on how this oil gear is supposed to be set up I see that the both of them have an arrow on them but will not line up correctly I think either it is one tooth before or after but the two will not line up together also is there a point that they should line up too on the house that I am not seeing?
HERE IS A PIC SO YOU CAN GET WHAT I AM TALKING ABOUT
Old 07-22-2009, 08:29 PM
Jay351's Avatar
Slide it so the arrows are where the gears are in most contact with eachother.
Mine lined up fine.
Old 07-22-2009, 08:33 PM
iamsuperbleeder's Avatar
I don't think it really matters to be honest
I searched till I was tired of searching, and finally just said screw it, and did like Jay said just to be safe, lined em up close, and then bolted the sum-bish on
There's more teeth on the outter gear than on the inner gear, so they're goin to get out of sync anyhow...
Old 07-22-2009, 08:39 PM
Ya I was thinking it should not matter because they turn differently anyway but thought I would ask in case there was a reason or purpose from them to be out of line with each other. Thanks Guy's
Old 07-22-2009, 09:11 PM
Ezrider_92356's Avatar
when i built my motor i did not even notice any marks on it and i did not line any up and my oil pump works fine.
Old 07-23-2009, 12:10 PM
makes you wander why the marks are on there to begin with
Old 07-23-2009, 12:35 PM
Jay351's Avatar
I doubt it even matters if they line up, all the teeth are the same so its not like something has to line up...
Old 07-23-2009, 12:57 PM
Ed H.'s Avatar
they rotate differently so it doesnt matter i read somewhere to just make sure the arrows are on the same side who knows about that though, i put mine back together and it works just fine, dont forget to prime it when you put it back together.
Ichneumon
09-27-2015 04:21 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Oil pump gear question
