Oil pan to timing cover question.
Is there suppose to be somewhat of a gap between these two? It's like this on both sides. If you look on the corner you can see where the timing cover is actually not flush with the engine block.
Your pan looks warped to me. IIRC when I did this my engnbldr tcover was fairly flush to the block, not perfect but better than yours. You're going to be using FIPG/RTV silicone gasket anyways, so goober it up and it should seal the irregularities - that's why we use it. I don't see why it wouldn't seal as long as you fill the gap and have done good prep beforehand.
Staff
All the bolts are the same. Your pan does look bent to me. I would suggest pulling it off and laying it on a solid surface and with a block of wood and hammer try tapping it to get it straight again. I have a tough time with leaks with a perfect pan. I feel your pain on having to pull it back off again. Been there a few times myself.
The Tick
01-18-2016 07:18 PM
WTB[PacNorWest]: 1992 4Runner parts - misc interior and engine hardware
Reluctanse
01-15-2016 06:04 PM
Redrezzer
01-12-2016 09:21 AM
