oil pan gasket problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-26-2007, 09:41 AM   #1 (permalink)
shoff's Avatar
I was installing my oil pan with a new gasket. I put a little red rtv sealant on the gasket and torqued the nuts to 9 ftlbs like the Haynes manual said. The gasket started squeezing out the side. This does not seem normal. What should I do leave it or replace it? Also how the heck do you put a picture up on a thread? I cannot figure it out......[IMG][/IMG]
shoff is offline
Old 07-26-2007, 09:44 AM   #2 (permalink)
Kaleb's Avatar
Send a message via AIM to Kaleb
go to tinypic.com and upload the picture. Then copy the code that says "IMG Code for Forums & Message Boards:" into your post.
__________________
MY BUILD
Kaleb is offline
Old 07-26-2007, 09:56 AM   #3 (permalink)
CyMoN's Avatar
part of the reason is these motors where designed to have sealant on the oil pans not a gasket.
also from my experience red sealant dose not seem to last near as log as the the high temp black or grey silicone that is oil resistant.
this might help also http://www.yotatech.com/f116/links-f...umbers-102344/
__________________
my rigs
89 4runner
1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed
86 pickup
1986 stock pickup 22r 31.10 BFG ATs flatbed
a sad day for the 4runner
"One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life."
CyMoN is offline
Old 07-26-2007, 02:22 PM   #4 (permalink)
tortis's Avatar
I had the same problem using the black rtv. i took the oil pan off replaced the gasket, used the black rtv and snugged the bolts down, then came back a couple of hours later and snugged some more. i think i ended up with 6-7lbs of torque. i think somebody makes a rubber gasket, but i don't remember who makes it..
__________________
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
tortis is offline
Old 07-26-2007, 02:44 PM   #5 (permalink)
CyMoN's Avatar
I did not know yo have the motor out I would remove the cork gasket and use the black high oil resistant silicon only just make sure to not put too much around the dipstick hole it can make it hard to check the oil
__________________
my rigs
89 4runner
86 pickup
CyMoN is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pan gasket ? cruisinforburgers 86-95 Trucks & 4Runners 11 09-25-2006 03:29 AM
oil pan gasket Localmotion 95.5-2004 Tacomas & 96-2002 4Runners 6 03-22-2006 07:30 PM
Oil pan - Gasket or NO gasket Dezertoyota 95.5-2004 Tacomas & 96-2002 4Runners 4 05-26-2005 04:03 AM
Oil pan gasket dropcivic 95.5-2004 Tacomas & 96-2002 4Runners 12 12-16-2003 01:09 PM
2009 InternetBrands, Inc.
