Oil Leaks
Oil Leaks
Found the leaks. Oil pan, Rear transfer case to Trans area and rear shaft. I do know how to seal the pan. I cleaned all of the areas and used a rag to seal off each area to isolate the front leak. Thank god it was only the pan.
I didn't realize the rear shaft had a seal. Is it coming from the transfer and dripping out?
Can i just take out the rear transfer to do these seals? Is that a pita?
