Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Oil Leaking into Rear Brake Drums
#2 (permalink) |
Personal
Sales Rating: (0)
Welcome.
Here's a good article on replacing the seals. You should also replace the brake pads. http://www.4x4wire.com/toyota/mainte...wheel_bearing/
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C, 4.56, 31x10.5x15 Nokian Vatiiva Tires, Taurus fan (removed) '90 4Runner SR5 V6 4X4 Auto, A/C, 4.56 V6 power with V8 fuel mileage I've used Fram oil filters and dino oil in all my stuff for 30 years and never had oil related trouble |
#3 (permalink) |
Personal
Sales Rating: (0)
Axle seals and possibly wheel bearings (bad bearings are usually why the seals fail). Once the shoes are contaminated with oil they're ruined...don't reuse them.
If you're looking for stuff to do while you're in there, you could replace the differential studs with bolts since you'll have the axles out anyway, and replace the pinion seal. With the stud elimination and FIPG between the diff/housing (no paper gasket), it will be a long long time before it ever leaks from there. http://www.yotatech.com/f116/differe...cement-241933/
__________________
1990 Xtra Cab 4x4 3VZ-E/R150F Swap ----- 2009 F-150 4x4 5.4/6spd Auto |
#4 (permalink) |
Vendor
Sales Rating: (10)
Rear axle/seal bearing kits one per side
http://www.wabfab.org/Rear-Axles/Rea...ypage.tpl.html New rear drum brake shoes
#5 (permalink) |
Personal
Sales Rating: (1)
If you don't replace the brake shoes, at least put them in the oven and bake the grease off, and I assume that you have verified that this is diff fluid leaking and not the brake wheel cylinders leaking.
I just recently replaced my third member studs with bolts and a word of advice if you do decide to do it, once you can fit 2 nuts on the end, it will make the job a lot faster to screw them in. Also, maybe extend the breather just as a precaution to getting water in.
__________________
1988 Pickup dubbed -Bucket-Build- Ongoing garage queen project at the moment Trail Gear 4.7 T-Case gears, Dana 60 front axle, 14 Bolt FF rear axle, All-Pro T-case parking brake, Dents and Stickers and now with lots more dents. 1998 Toyota 4runner Limited- 4wd, Automatic, 3.4 5vze and Rear E-Locker Daily Driver. |
| Tags |
| 99, axle, brake, break, caravan, cylinder, drive, drum, fluid, leak, leaking, oil, pad, rear, seal, truck |
