| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
oil leak update (old engine cleaner thread update)
__________________
RB4R Life Member. 1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header. |
#2 (permalink) |
__________________
JASON 1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny 31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod |
#3 (permalink) | |
Quote:
Jason thanks for all the schematics (spelling?) I can't count how many of these I've printed from you posting them. So we're looking at what a 2 or 3 hour job to replace this little beast? Anything else I should replace while I'm in there?
__________________
#4 (permalink) |
if you do..take some pics and write up if you have time..that would be sweet
good luck
__________________
1987 Pick Up 2.4L 4x4 2004 Rallirt 2008 Taco |
#5 (permalink) |
If the motor you are working on is the one in the pic, I would imagine it wouldn't be too difficult (never did it personally). If it's in the truck...well let's just say that would be a different story.
Looking at the manual, it looks like you will need the O-ring. Have you changed the oil pump already?
__________________
JASON 1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny 31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod Last edited by jason191918; 09-16-2008 at 05:08 PM. |
#6 (permalink) |
We did that on my girlfriends 95 22re runner.. The hayes manual said you need to drop the oil pan, which requires the diff to be dropped... WRONG!!
Its a pretty easy repair, just be carefull with the gears inside that pump...
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#7 (permalink) |
Jay Knows All.
__________________
#8 (permalink) |
No oil pump change so far and no that isn't my motor in the pic, mine's in the truck. I'll grab the parts and do it in frame with as many pics as I can snap.
Thanks guys.
__________________
#9 (permalink) |
Thats sig worthy
![]() Its pretty straightforward. Though I can't remember if I drained the oil before I took it out or not....
__________________
#10 (permalink) |
In that case you might want to do timing chain, oil pump, water pump, etc. Jay would know.
__________________
#11 (permalink) | |
Quote:
The 4x4 and lifted trucks are easier to change as you can work from the bottom vs having to bend over and reach down from the top. Don't forget to get the shaped O ring for the pump housing as you will be taking it off to replace the main seal. Good time for belts too as those will be off. |
#12 (permalink) | ||
Drain and drop rad
drain oil remove belts remove crank pulley- don't dare ask, search the rest is self explanatory if i remember correct
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#13 (permalink) |
We didn't have to touch the radiator.. did you have too?
__________________
#14 (permalink) | ||
You don't have to actually, your right. I was doing the timing chain so I did that as well. I stand corrected.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Update on New Engine - :( | My99 | 86-95 Trucks & 4Runners | 40 | 11-11-2009 09:40 PM |
| *UPDATE* Oil Pressure Problems | 84YotaBigRig | 84-85 Trucks & 4Runners | 0 | 08-16-2008 06:09 PM |
| Engine light on (update) | Wildwood4runner | 03+ 4Runner/GX470, & 05+ Tacomas | 2 | 06-14-2007 02:51 PM |
| 4x4Lamm's 1995 4Runner Build-Up Thread (update) | 4x4Lamm | Build-Up Section | 0 | 11-30-2006 09:42 PM |
| The "FUND" Update Thread | waskillywabbit | Off Topic Talk | 6 | 11-10-2005 07:52 PM |
