Oil leak issues
Old 01-19-2010, 11:52 AM
joeynational's Avatar
Oil leak issues
I'm in the middle of a tune up on my 91 22re..As I went to pull the 4th plug i noticed a big wet spot. Took the plug out and figured out it was coming from the plug hole. I did a top end rebuild about 3 years ago with Engbldr parts, so my valve stem seals were replaced, which leaves the rings right? Is it rebuild time? Will I ruin the new spark plug with this oil leaking in there..
I have not done a compression test yet, but I plan on buying one shortly and checking it..just looking for some advice
plugs in cylinder order from left to right
another shot of #4
Old 01-19-2010, 11:59 AM
PirateMcgee's Avatar
looks like an oil leak from the backing plate or back of the valve cover could be from the coolant line aswell
doesn't look like it's coming from the spark plug hole to me....
Old 01-19-2010, 12:13 PM
turboboost's Avatar
I agree with the guy above me. Looks like an external leak of sorts.
Old 01-19-2010, 12:24 PM
75k5toy's Avatar
3 x ,,,,I think it's leaking from the rear half moon seal.
Old 01-19-2010, 02:23 PM
Chuki's Avatar
Looks like a valve cover gasket leak to me. If it was the cylinder, your spark plug would seal it off, so you would have no visible signs like that. Based on the pic, I'd say the half moon seal is leaking in the back, dripping onto the rear water bypass, and then onto the head.
Just get a new valve cover gasket set, and make sure and use some silicon on the half moons to help hold them, and each corner to get a good seal.
Old 01-19-2010, 04:07 PM
ok, its not the valve cover..it completely dry back there...BUT.........am I supposed to have a bolt right there where the red line is at...Because i don't, can someone please verify..thanks
Old 01-19-2010, 05:32 PM
75k5toy's Avatar
no there's nothing there, I went out and check a head i have on the yard.
Old 01-19-2010, 05:39 PM
75k5toy's Avatar
Hey Joey. take that hanger off. may help to see where's comming from.
bigjstang
08-25-2021 12:41 AM
Eggslinger
06-08-2019 03:32 PM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Oil leak issues
