oil leak@drums
Old 03-08-2011, 06:19 PM
polycrack's Avatar
oil leak@drums
I have axle oil in my drum brakes 87 4runner .can I just pull the axle and replace the inner seal? or does the outer need to be done? i'm still searching just looking for a quick answer
Old 03-08-2011, 06:20 PM
waskillywabbit's Avatar
http://www.4x4wire.com/toyota/mainte...wheel_bearing/
:wabbit2:
Old 03-08-2011, 07:35 PM
peow130's Avatar
Pull the axle and find out the condition of your inner and outer seals.
Chances are, both are bad.
You'll probably need new pads too.
Old 03-09-2011, 08:43 PM
polycrack's Avatar
replaced the inner today i belive the outer is only for dirt and watter. it a sealed bearing so it doesn't need the gear oil for lube. I'll see how it does
Old 03-09-2011, 08:46 PM
James Woods's Avatar
I have heard that you can bake the grease off them in the oven, never tried it myself.
Old 03-09-2011, 10:45 PM
polycrack's Avatar
you mean for the pads? or shoes in my case
Old 03-10-2011, 10:03 AM
Yes, I have heard that you put the shoes in the oven and bake the grease off, I am not sure if it works or the temp, just heard that it works.
Old 03-10-2011, 09:45 PM
polycrack's Avatar
looks like the inner seal stoped the leak. It was a ez fix
Old 03-11-2011, 07:40 AM
blue_CA_yota's Avatar
That might work, but gear oil smells horrible.. your better half would never forgive you..
Eggslinger
06-08-2019 03:32 PM
Ladythump
22
11-09-2015 08:53 AM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: oil leak@drums
