Oil leak can't find rebuild 89 Toyota with 86 mortor
Old 07-20-2013, 07:36 AM
89crock's Avatar
86 Toyota pickup have an oil leak its all over front of motor I replace lower seal and the o ring on the distributor no luck sill have oil all over I have cleaned it more than enough times but its hitting a belt and is heavy oil when I get good pressure ( Help )
Old 07-20-2013, 07:50 AM
thefishguy77's Avatar
Well I am assuming its a 22r or RE. I like to throughly clean the motor first. Oil Eater works well for me and its pretty safe as well. First get the complete motor clean. ALWAYS wear eye protection when spraying any liquid to prevent splashing back in your eye. I use straight oil eater and spray it all over the motor with a spray bottle. I usually opt for more of a stream and less mist helps to force it in to some of the crevices on the front and side of the motor. Let it sit for a minute or 2 the. Hose it off. Find the areas that need another coat and repeat till it looks new.
I then get my handy little telescoping mirror throw it I. The passenger seat and go for a quick drive mile or 2 at most. Stop and pop the hood and begin to look. Don't burn yourself (extendable telescoping mirror). Take your time and look all over the motor. If its still clean the another. Short drive maybe a little longer or harder. Stop look. You get the idea. If its spewing really really bad might just be able to start it and let it run in the driveway. But most leaks show up better under load. Good luck and make sure and take pictures of your clean motor. It will help you stay inspired to keep that bad boy clean. Because they look awesome clean.
duckhead
170
11-13-2017 06:07 AM
JF9243176
10-08-2017 04:21 AM
JF9243176
06-24-2015 04:53 AM
newzingo
06-19-2015 04:37 PM
Juan Manzione
06-10-2002 04:12 AM
Quick Reply: Oil leak can't find rebuild 89 Toyota with 86 mortor
