oil leak from back of engine
Old 02-14-2008, 02:53 PM
tacurt's Avatar
I had noticed puddles in my drive so I replaced the valve covers, thought it was coming from the back of of covers. I'm still leaking somewhere? The drip is coming off the bell housing for the transmission. I can't see where its coming from. Where could oil be leaking from the back of the engine knowing the valve covers are new?
Old 02-14-2008, 02:58 PM
bigarms23's Avatar
it sounds like you need to replace a gasket
Old 02-14-2008, 03:03 PM
Elvota's Avatar
My guess is the rear main seal... that requires a tranny drop to replace.
Old 02-14-2008, 03:06 PM
rngrchad's Avatar
Rear Main. This is extremely common. I just replaced my front main seal while I was putting a new oem water pump on. The front is a piece of cake compared to the rear. Good luck.
duckhead
170
11-13-2017 06:07 AM
JF9243176
10-08-2017 04:21 AM
ian1386
07-01-2015 11:23 AM
JF9243176
06-24-2015 04:53 AM
newzingo
06-19-2015 04:37 PM
Quick Reply: oil leak from back of engine
