oil leak
oil leak
I just replaced the water pump on my 22re.... before i did this, it had a small oil leak(they all do). Now, the oil is pouring out of the front of the motor... did I do something wrong?
no, If i could pin-point it, I wouldnt have a problem.... it seems like its just everywhere in front. the new water pump is covered in oil, so im guessin its comin from the top somewhere...
there's only a fwe places it could be leaking form in the front...from top to bottom...the vavle cover gasket....the HG( the part between the head and the timeing chain cover...and the front main seal(crank shaft seal)...that's al i can think for oil to leak from in the front of the enige
