Oil in intake
Old 08-25-2008, 05:45 PM
bikerbob's Avatar
Oil in intake
I pulled the intake on my 22re to clean it out. In the lower intake I found carbon build up,normal, but number 3 and 4 cylinders had some wet oil. Is it normal for there to be wet oil in only these two cylinders?
Old 08-25-2008, 06:27 PM
just a 22re's Avatar
thats not normal man
Old 08-25-2008, 06:35 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
How many miles on the motor? Could be the oil rings are worn...and probably is.
Old 08-25-2008, 06:38 PM
yeah but then theres a valve problem to then making it go into the intake unless your pvc is shot?
Old 08-25-2008, 06:53 PM
MMA_Alex's Avatar
the pcv will allow some oil through and it'll gunk up the intake
Old 08-25-2008, 06:56 PM
thook's Avatar
True this!
Hey Alex...long time!
Old 08-25-2008, 08:58 PM
bikerbob's Avatar
The motor was rebuilt 55000 miles ago.
Old 08-25-2008, 09:31 PM
MMA_Alex's Avatar
yeah, im back hanging around for awhile.
I wouldnt worry about a little oil in the intake. clean it out best you can
Old 08-25-2008, 09:55 PM
thook's Avatar
Oh, in that case, shouldn't be anything to worry about. Just make sure the PCV valve is working correctly....as in, not sticking or anything.
On the other hand, did you do a follow up valve adjustment after the rebuild?
Old 08-25-2008, 09:56 PM
thook's Avatar
Cool beans....
calderp
Engine Swaps
08-16-2016 05:15 PM
RatOmeter
10-22-2015 03:17 PM
yourrealdad
07-29-2015 11:08 AM
calderp
07-27-2015 09:58 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Oil in intake
