oil gauge question
Old 08-21-2009, 08:48 PM
sundog kid's Avatar
oil gauge question
I noticed my truck idles warm at around 600 rpm, and the oil gauge shows at idle about middle of the first bar, then fluctuates to middle or more of the middle bar when im driving.(if that makes sense)
1) is this normal? Im not used to older gauges, and have never seen such a fluctuation, although I under stand as the revs increase so does oil pressure.
2) whats the normal rpm's for idle at warm?
Old 08-21-2009, 09:11 PM
abecedarian's Avatar
IF you connect a mechanical gauge, you should get 7-10 PSI at idle, 750-850 rpms, and a minimum of 35 PSI at around 3500 rpms. These are not 'hard' values but you should never see less than 7 psi at idle and should see at least (RPM's / 100): 3500 rpm- 35 PSI, 4000 rpm- 40 PSI, etc..
Old 08-21-2009, 09:17 PM
2DoorRunner's Avatar
yeah your fine.
Old 08-21-2009, 09:21 PM
sundog kid's Avatar
alright. I mean, theres a tick to the engine, thats either lifter noise, or an exhaust leak at the manifold, or just a typical tick to toyotas. But I thought, maybe it might be low oil pressure.
Old 08-22-2009, 12:00 AM
Jay351's Avatar
Mine reads 0 after its warm
Old 08-22-2009, 01:18 PM
sundog kid's Avatar
Im going to take a small vid clip of the ticking, and let you guys tell me if its a typical toy tick, or if im running bad lfiter noise.
bigjstang
08-25-2021 12:41 AM
the1998sr5
15
07-14-2020 08:35 PM
thefishguy77
07-30-2015 10:59 AM
88yodabasket
07-13-2015 01:32 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: oil gauge question
