oil cooler part id
Old 03-27-2007, 04:16 PM
justinking060310's Avatar
oil cooler part id
what piece is that? i dont have the cooler to look at right now and I am trying to figure out if i need to replace it.... i have the 2 o-rings and the 2 hoses.....
kat
Old 03-27-2007, 04:22 PM
Babypig's Avatar
That would be the oil seal i believe.
slosurfer's Avatar
It is an o-ring that seals between the cooler and the engine block. I would replace it while you are in there.
Old 03-27-2007, 04:28 PM
ok, that probably clears up the note i made- "o ring to oil cooler bracket - oil cooler and bracket assembly"
So there is a total of 3 o rings - the one big one and the two little ones.
Old 03-27-2007, 04:52 PM
JEBSR5's Avatar
That would be correct.
Old 03-27-2007, 04:53 PM
Thanks a ton!
Old 03-27-2007, 05:00 PM
AuburnRunner's Avatar
justin.... could you give an update on how this went once its done? I've been needing to install new oil cooler o rings but it looks super cramped up there, and I've been lazy.
Old 03-27-2007, 05:05 PM
i have my motor out of the truck, but i will take pictures for you
see my head gasket thread for a bunch of pictures...
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Gamble_STi
07-07-2015 07:54 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: oil cooler part id
