oil in coolant
Old 09-25-2008, 08:08 AM
Cwaters1184's Avatar
oil in coolant
Someone please tell me if you can say for sure this is oil? cause its not milky or dark, just those little floating particles.
http://img.photobucket.com/albums/v1...Coolant001.jpg
Old 09-25-2008, 08:10 AM
jason191918's Avatar
Could also be oil cooler or lower intake gasket. Take it you are low on oil?
Old 09-25-2008, 08:12 AM
nope oil is right on full.
Old 09-25-2008, 08:23 AM
ive read it could be the timing chain rubbing the timing cover.
Old 09-25-2008, 08:26 AM
IIRC, you can remove the valve cover and get a flash light to check for that one.
Old 09-25-2008, 08:35 AM
i dont know how to go about doing that. i mean i can take the valve cover off, then ill beable to look down into the timing cover? if so then im just looking for a coolant leak or a worn spot?
Old 09-25-2008, 08:49 AM
Broomie's's Avatar
When you get the valve cover off, look down the left side for this.
If the plastic guides are gone then it is the timeing chain eating thru the cover into the water pump area. you will need to replace it fast or you will lose you engine.. The timeing chain and cover. look on e-bay for the cover, you will find them there cheaper.
Old 09-25-2008, 08:53 AM
thanks for that. so if it is that then once i replace the cover and i guess the chain it'll be fine?
Old 09-25-2008, 08:57 AM
Broomie's's Avatar
no you will need to replace the chain at this time, because it got old and streached out and caused the problumes you are haveing..
Old 09-25-2008, 09:11 AM
yeah thats what i was saying, but im noticing it is giving off some white smoke when i get on the gas a little. Deff a coolant/oil leak somewhere.
Old 09-25-2008, 09:38 AM
also is this the water temp sensor?
Old 09-25-2008, 10:39 AM
4rnr's Avatar
Do you have any cooling issues? Have your coolant checked for hydro carbons.
Old 09-25-2008, 08:08 PM
nah, like i said nothing seems to leak and the oil isnt milky like most people say it should be.
from looking at the pic in the OP can someone tell me for sure if thats oil? could it just be gunk and need to be flushed? cause from what im reading i doesnt seem like it. idk! help!
Old 09-25-2008, 10:22 PM
night bump for answer
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
jasonty
41
12-23-2018 01:00 PM
WellsR
12
07-31-2015 03:27 PM
krimsonone
07-29-2015 11:53 AM
Quick Reply: oil in coolant
