Oh snap! No start!
1 Post
Oh snap! No start!
Whenever I go to start the car either in the morning or night (must be cold engine), and ever since it has gotten cooler out.
When I try to start it just clanks(starter contact) and clicks(relay), but just once, until I try again, and again, and again.
Finally after a bit if turning the the key alot, it starts. Usually normally, sometimes a bit rough then normal.
Last night was the worst, and also the coldest. It took like a good minute, minute and a half, and then when it finally started, it was really rough, even if I gave it gas, and then I grew concerned and then it was normal.
A little background info, I doubt the O2 sensor has ever been replaced. I realize this because no matter how I drive (from flooring & hard braking, to calm, gentle acceleration with a max of 2.5k RPM) I still only get 14.0 to 15.0 MPG. Even if I make it run rich or lean 3 clicks.
Please help!! Its my DD!
Thanks!
Thanks!
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Check your Cold start injector and cold start injector time(?) switch.....and like Abe suggested, have any codes?
1 Post
No CEL, but I'll see if their is any codes (probably Tuesday)
I realize that the O2 has no influence on cold starting, but I was wondering if that would have to do with MPG, using the scenario I listed.
my truck currently does this.. because my cold start sensor fell off.. but when it was getting weak she was having trouble starting cold and is only now throwing CEL
1 Post
Ok guys, REALLY need some solid help.
Today I was 10 minutes+ late for school, and after school it took 5 minutes for it to even begin cranking.
After it starts to crank, it runs rough and if i let go (the key) it dies, so i give it gas, then it smooths itself out.
I REALLY need it because I can't turn the car off, otherwise it takes awhile. BTW, it gets worse everyday.
And it is not the battery, or the amp, or the charging system.
Could it be all i need is a big 3 upgrade, along with a new wire to the fuse box, or the relay inside by the pass footwell (it clicks loudly), or the starter itself, or the starter contacts?
I would REALLY appreciate all responses! thanks!
1 Post
I have a million things I could say right now, but I would get banned. :p
Long story short, I'm stuck 50+ miles from home in Chicago.
thankfully I wont get charged for overnight parking, but I won't be going to school tomorrow, so that kinda sucks.
Two guys tried to help me, but nothing worked. I mean a guy in FORD F350 was helping me, from West Virginia (and he claims that it has 211k on it ['04])
So now I have to pay to get it towed, plus a new starter. Oh the joys of bieng 17 and poor.
I have a video of me trying to start it, if you guys want me to post it.
Poncho0206
07-10-2015 06:21 PM
