Off The Wall Question About Engine Computers.
Old 10-18-2009, 07:31 PM
myyota's Avatar
Everyone here with a 22RE is always looking for power/performance out of there engine, we can upgrade the exhaust, the head and cam, and swap in a larger AFM, but what about the computer ?, is there a computer from a celica or other car/truck that would be plug and play and maybe gain us a little more power or performance ?. There probably isn`t anything thats plug and play, but i was just wondering if there was.
Old 10-18-2009, 07:39 PM
abecedarian's Avatar
sdsefi, megasquirt and maybe some other aftermarket engine management systems are out there.
Old 10-18-2009, 07:44 PM
myyota's Avatar
I know theres a bunch of after market stuff you can buy, i was just wondering about toyota parts and if anything is swapable from one year or one vehicle to the next ?.
Old 10-18-2009, 07:51 PM
You're more limited by the design of the engine than the electronics hence why there aren't many options out there. The stock ECU can support a mild turbo up to about 130 HP so not much need to swap it out unless you're building a significantly modified engine. Early celicas were analog efi so those aren't interchangable and the FWD Celicas use a substantially different system than our trucks so likewise aren't interchangeable.
The aftermarket units allow you to fine tune ignition and injection parameters which can help the efficiency and power output of the engine.
Old 10-18-2009, 08:15 PM
myyota's Avatar
I didn`t think there was anything out there other than expensive after market stuff.
kazuya2416
04-05-2024 02:17 AM
bigjstang
08-25-2021 12:41 AM
TURBOrunnerNM
07-22-2015 11:01 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Off The Wall Question About Engine Computers.
