OEM Skid Plate Bolts
Does any body know what size the skid plate bolts are for a 95 4runner? I just bought the truck and the person I got it from had 1 bolt holding the SP on, it doesn't fit the rest of the holes where bolts should go.
Thanks!
Thanks!
No, I don't....BUT....go to www.toyodiy.com and you can find alot of info. I have a 1992 truck but it should be the same........or better yet go on some toyota parts sites and type in this part# 90119-08776...this is what is listed for that bolt.
hope that helps.
hope that helps.
Thanks for the help fellas!! Next step will be figuring out where the leak is that looks to be coming from somewhere between the motor and trans. Not a bad one but a couple drops a day.
Thanks I have a feeling its the rear main. That's a pain to get to I'm pretty sure. The valve covers have a little grease on them but it doesn't look like its coming from that high. They could stand to be replaced also. Thanks for the replies.
06-01-2021 01:51 PM
BeMiceElf
10-10-2015 09:40 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
