Odds Of Bent Frame Question
I was wrecked into and I am wondering what you all think the chances are that the frame is bent.When I look at the frame itself it looks straight but you never know with such damage.Is there a way to check the frame without taking it to a shop?Maybe with measuring?The axle is broken at the wheel and seems that it took all the impact.I found a bed($300)and I found a rear end($100)but I want to check the frame before I spend any money.Sorry about the picture quality I took it at dusk.I will try to get better ones tomorrow.Thanks in advance for any help.
Ide say measure it and get some other peoples measurements to go by. It could bend fairly easily. Its 1/8" wall. Could turn it into a sick buggy with a tubed back section Sorry about the accident that does suck
you can get dimensions from the FSM, You'll need a tool to do the measurements. I think they call it a tram guage. you can make one of these with out much difficulty.
I just use my eye
Thanks so far for the info. and I welcome any advice.I will be taking the bed off in a few days.That will be new to me but should'nt be too difficult.After that I should get a real good look at it's condition.
I just put a new bed on and I think it's bent about a half inch.The bed gap between the cab and bed is 1" on one side and 1 1/2" on the other.I tried and tried to get the gap even but the bolts wont allow it.Can I still drive it no problem?I will try again tomorrow to get it even.I'm thinking maybe I can file the bolt holes on the bed.The gap is really not that noticible.Anyway,what do you all think?
with that gap your frame is most likely bent. you just dropped $400 bucks in parts why not have the frame pulled as well? for another couple hundred you could probably have it fixed. every body shop i have ever worked at has given free estimates, find a local shop and see what they say. it is technically called a tram guage but i prefer the slang term monkey-on-a-stick.
sure some of the bed mounts arent a lil tweaked. The 4 towers up front could of bent some... seems plausible to me. From the damage in the pictures seems likely the two on that pass side could of gotten tweaked
It did take the hit directly to the wheels.I drives perfectly straight as far as I can see.I will take it to a shop for a look as long as it's a free estimate.If they say it's around $200-$300 that sounds fair.
