odd issue on freeway, just died for a second...
Old 01-03-2012, 10:41 AM
JohnVH's Avatar
cruising along at 70 and its like it shut off for about 1 second, check engine light flashed, then it took off again like nothing happened, it was so fast. Anyone ever had this? Never done it before or since, it runs great.
Old 01-03-2012, 11:19 AM
BMcEL's Avatar
Way too many variables here...pull the code first.
Old 01-03-2012, 01:58 PM
TNRabbit's Avatar
MOST intermittent issues like that are an electrical short. Could be a bear to find....
Old 01-03-2012, 08:13 PM
92dlxman's Avatar
bets on code 14!!!!! my 22re i moved one ground from a black bolt to a gold one and inspected/heavily re-wraped the wiring harness.
go through a puddle or a car-wash and i bet it dies.
this problem plagued me for litterally years. intermittent for a the first year or so then steadily got to wear the truck was completely not driveable
Old 01-03-2012, 08:50 PM
JohnVH's Avatar
doesnt die in the rain, snow, dry, or anything, yet. Its just a bad ground?
Old 01-04-2012, 07:32 AM
BMcEL's Avatar
Again, look for codes...if the check engine light flashed when it happened, that code should be stored in the ECU.
Anyone can guess what happened, but your truck most likely knows what happened.
If you don't know how to pull codes, read:
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Old 01-04-2012, 10:53 AM
alltracman78's Avatar
Check your codes, but keep in mind that if the engine completely died for a second the light flashing is completely normal [key on, engine off the MIL should be on].
Old 01-04-2012, 11:29 AM
JohnVH's Avatar
yeah, I will, its rainy here so Im waiting for a break to go screw with it, hopefully it directs me to something simple.
Old 01-04-2012, 12:11 PM
MudHippy's Avatar
It's not that uncommon an issue, it even happens with some 22R-Es. My 88 3VZ-E does it, and code 11 is everpresent. It could be caused by a faulty relay(COR or EFI main), a failing VSS, a short in any of the wiring supplying power to the ECU, any combination of such things, or for reasons unknown. And there may or may not be any codes present as a result.
Other than replacing the VSS and/or the COR and/or the EFI main relay on mine, I still can't figure out what's the deal with it. All of which "appear" to be in good working condition after thoroughly inspecting them so...
Here's some reading material on the subject:
http://www.motor.com/article.asp?article_ID=271
https://www.yotatech.com/forums/f116...e-nuts-186678/
Old 01-04-2012, 08:07 PM
92dlxman's Avatar
im dead serious about the wiring harness. i dont think the ground had much to do with it. check codes first. like i said my money is on code 14. if its that, i may be able to help, because i learned wayyyy too much information about the igf signal in my tribulations.
Old 01-05-2012, 06:10 AM
Cyberman's Avatar
Same problems here. Been plaguing me for a while. Engine light flashes, dies, then recovers. No codes. One of these days, I'll get it figured out. If I could get my hands on a cluster, maybe that might help.
Old 01-05-2012, 06:45 AM
JohnVH's Avatar
guage cluster?
Old 01-05-2012, 06:47 AM
Cyberman's Avatar
VSS 1, from MudHippy's first article. FWIW, I've replaced almost every ignition component, to no avail. From my reading, it's either the Circuit opening relay, a bad ground, or maybe the ignitor (haven't replaced).
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
Alex Bessinger
08-31-2015 09:17 AM
tomczaksdiesel
07-26-2015 10:35 PM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: odd issue on freeway, just died for a second...
