Odd breakage. 93 4runner. lower control rod mount
Old 04-05-2010, 04:45 AM
nsb22's Avatar
The passenger side lower control rod mount, the bracket that attaches to the frame, has either rusted through or broken.
Has this happened to anyone else? Should I trust the junk yard for this part?
Thanks,
Old 04-05-2010, 07:12 AM
yayfortrees's Avatar
What's your ride?
If it's a truck like mine, that mount is welded to the frame.
Old 04-05-2010, 08:13 AM
nsb22's Avatar
Sorry, it's a 93 4runner. Looks like it's mounted with a couple of bolts. Rear axle, in case I didn't say.
Old 04-05-2010, 08:25 AM
Nevermind! I would say that a junkyard part would be fine, as long as it's not too rusted out. Just make sure you inspect it well before buying it. Any other mounts need to be replaced? Might as well check everything out well, if there's a mount like that on the driver side, I would go ahead and replace it at the same time as the other one.
Old 04-05-2010, 08:47 AM
nsb22's Avatar
Yea, I was already thinking about changing the other side as well. If my shocks would ever get here, I'll have new springs and new shocks as well.
Old 04-05-2010, 08:54 AM
Ooh, I'm jealous. I just put new shocks on, but I have to wait on the springs. Mine aren't completely flat, but they're not far off the overloads. Enjoy the sweet ride!
Old 04-05-2010, 11:38 AM
nsb22's Avatar
Well crap on me. Just talked to the toyota parts lady near me. She said this mount is welded to the frame. What the hell do I do now?
Old 04-05-2010, 11:46 AM
hilux1026's Avatar
go and have one cut off of a wreck at the salvage yard and then have a shop weld it on. Make sure you take plenty of measurements first though. either that or swap to leaf springs
Old 04-05-2010, 11:50 AM
Fossilized
Staff
dropzone's Avatar
fixed your thread title--in the future use a more descriptive thread title...
might want to add your truck to your signature--helps eliminate fishing for info trips
Old 04-05-2010, 11:52 AM
nsb22's Avatar
Thank you sir. Sorry about that.
What are the advatanges to switching to leafs? How will it affect towing capacity?
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
terminator
07-27-2015 07:13 PM
1994toyota
07-17-2015 03:03 AM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Odd breakage. 93 4runner. lower control rod mount
