OBD 1 reading
after looking through my links, i found a site that might have one in stock:
RARE! FOR SALE: OBD1 Scanner Tool
There does exist a "scan tool" for Toyota OBD 1, but I've only seen drawings of them. They can retrieve information like injector-open-time, fuel trim, etc.
But I think what sqwadoosh wants is a "code reader." And yes, the SST (Special Service Tool) is (now) a paper clip. http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
yup, code 51 and code 21. now you have a good starting point
>code 21 is oxygen sensor
>code 51 is tps idle circuit
(and yeah, we like to give everyone who asks about it a hard time. and now you can tease the next person, haha)
I think 41 is the TPS idle circuit. 51 is "Switch Condition Signal," which isn't really a malfunction. It just means the A/C switch was on when you retrieved the code.
Code 21 indicates a failure of the O2 Sensor heater circuit. Almost always a bad O2 sensor, but those sensors cost enough, and the test easy enough, that's it worth testing it first. http://personal.utulsa.edu/~nathan-b...01heatedox.pdf
So I am having a high idle (1500-2000) once the truck warms up. I read on another post that if this happens to get out of the truck, pop the hood and tap on your tps. If the idle drops then you know your tps is bad. Can anyone tell me if this is true? I did do just that and the idle did come down. I just want to make sure before I spend the money on a new tps. Thanks for all the help fellas.
It's just as likely that you have a good TPS that isn't quite adjusted right. You have to adjust the new one if you replace it, so you might as well check the adjustment on the old one first.
nframe
3.4 Swaps
08-16-2015 09:03 AM
Colington
08-13-2015 02:21 PM
rjtrials
08-06-2015 07:25 PM
