O2 sensor wire 86 runner
Location: Yotatech, because Pirate is too expensive. NorCal.
Im trying to put my truck back together after the crazy PO and I cant find where the o2 sensor plugs into. The wire that comes off of the o2 sensor is the female half of a plug and I need to find out where the male half is hiding. Can anyone point me in the right direction?
Thanks
Thanks
The factory routing comes from around the passenger side in the big bundle of wires and seperates at the driver's side wheel well.....right around the ignition coil. If you don't see a single shielded wire coming from there, you'll need to just start looking around for it. It's seems unlikely it would be completely removed from the bundle, so I'd start from there.
Thanks guys, that should work but at the moment im 500 miles from the truck so if I have more questions when I get back, then ill just post here.
voiddweller
19
05-02-2016 09:10 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
