O2 sensor grommet
O2 sensor grommet
On an '88 SR5 4x4 with 22RE I have just replaced the O2 sensor with a Denso unit that I bought on eBay instead of from Toyota. It came without a grommet for the gaping hole under the driver's seat. Is there a preferred way to plug that before fording rivers, or splashing through puddles anyhow?
I have the old grommet in decent condition still on the old sensor wires. I could easily snip the wires and take it off, but then forcing the new connector through the grommet's aperture would be like a gerbil giving birth to a hippopotamus.
I was thinking of resorting to a gob of silicone sealer unless someone comes up with a better way.
Finally figured it out. You can unclip each terminal pin from the connector body with a probe-type tool. Then pass just the four wires through the center of the old grommet and reassemble the connector.
Obviously you need to keep careful track of which individual wire goes where.
zz_denis
09-06-2015 03:43 PM
