O/D Warning Light
O/D Warning Light
I have a new one for you wise yoyatech'ies, I 've finally gotten my 93 4runner on the road, bought it used & not running, Has a 3.0 with A/T , The issue now is sometimes when I start out its very sluggish and the O/D Trans warning light will flash on the dash, I drop into 2nd , it picks up drop back into D , Runs OK , O/D light goes out after a min or so.
Any Ideas? As always Thanks for the Help....
have u tryed pulling the codes for the issue? same as u would for the ecu do it for the trans, count the blinks and look in the book, it will tell u what is going on,
O/D Warning
Thanks Justin I'll ck That, I've seen some say you can use a paper clip if you don't have the correct tester, do you know if this is a proven method? I deal with Murphy (law's) daily,
Hey Justin, I see your from Tacoma, My wife and I are hoping to move to the Seattle area in Aug, Do you know of any 4 wheel clubs ( Toyota preferred) in that area you'd recommend?
i have not joined or really found any groups for toyota group yet, i have just go with a buddy of mine that has a jeep and i wheel with them. i have not hooked up with many guys off this group.
BeMiceElf
10-10-2015 09:40 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
Odin
07-15-2015 09:28 PM
