not sure what to do with the runner now, looking for opinions
Old 07-16-2010, 11:03 PM
vanderwiel's Avatar
So heres the deal... i have a 94 5 spd 3vze. The clutch has very little life left, and its beginning to show symptoms of a bad head gasket... it smokes sometimes on startup and it smells like coolant.. but this only happens say 1/5 times
The problem is i dont know what to do with it once it finally s the bed, should i replace the clutch and headgasket or is an engine swap the better way out... 3.4L or 4.3L gm? 7m?
Its my dd, id be going for the best "bang for the buck" solution.. the 3.0s lack of power is frustrating which is why i began looking at swaps..
just looking on some opinions... i dont mind spending some dough on this but it has to be reasonable
Old 07-16-2010, 11:07 PM
4x4jeffyota's Avatar
i would go with the 4.3, very strong motor, easy to find, and descent on gas. Im doing the swap next spring.
Old 07-16-2010, 11:17 PM
vanderwiel's Avatar
Originally Posted by razed
dont know where you live but engine swap is going to be the best option but what you can swap to depends on the rules where you live.
I live in New York
I have access to a 97 s10 4.3.. allegedly the engine only has 90k or so on it while the body has about 170,xxx.. can probably pick the truck up for 500 or so.. one reason why i considered the 4.3
Old 07-16-2010, 11:26 PM
thats a pretty good deal, i would buy it, then check out advanced adapters for other parts you will need
Old 07-17-2010, 06:51 AM
wii_tarded's Avatar
On the 4.3, you will need an adapted bell housine, I don't know if the motor mounts will work... :shrug: The 3.4 will bolt in to the 3.0's mounts and straight to the trans. My sig has a link to a company that can help with the wiring harness and crossover. 3.4's are reliable and better performance than the 3.0. What ever you do....POST PICS!!!
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
musashi86
California SoCal
07-07-2015 03:31 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: not sure what to do with the runner now, looking for opinions
